WD-45 Dilemma
bmarian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmarian Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 Dilemma
    Posted: 29 Aug 2025 at 8:26am
This thread is a little long sorry but the story is kind of important mostly to me! I have been lurking on the forum for quite a while and have gotten great information about the AC tractors that have been a part of my life for the past 50ish years.
I have a WD-45 dilemma, I picked up the pictured tractor for parts which as you can see it is pretty rough.  It has a snap coupler and my 1957 Wide Front WD-45 does not have the snap coupler so I thought that I would bring the 57 back to what I wanted with this tractor.   It turned out the tractor was less than 8 miles from my house here in Texas and the seller trying to sell the tractor for several months.  He needed the tractor off his trailer, the problem was that the left rear wheel was locked up and it was a real pain to load the tractor.  We cut a deal and he was going to deliver the tractor and take all the scrap metal to recycling after I got the parts off the tractor.  Funny thing is I already have a 55 and 57 WD-45, 2 Farmall Cubs, and we bought my wife a 2021 Massey Ferguson 1840M tractor as well.  Of course the Massey was at the dealer’s because the Air Conditioning was not working again, the 57 tractor was not starting and the Cub was getting a new sediment bowl and 12 battery.  And the 57 was blocking the 55 WD-45 so it was harder to unload without a running tractor to pull it off the trailer.  The other options to pull it off the trailer was our Ram 1500 4x4 pickup but that has highway tires that have about zero traction on grass.
With the help of a floor jack under the drawbar we managed to get the tractor to the end of his dovetail trailer.  The floor jack needed to come out so I decided that I would put a long tow strap around the left rear axle housing on the tractor and take the ramps off the trailer so we only need to move it another foot or so and then we would have the seized left rear in the grass.  At least that was my plan.  I though with a little luck we could pull his truck and trailer forward while I held the brakes on my truck.  It didn’t work out that way.  I left the truck in 2 wheel drive just to tighten up the strap since I thought maybe I would need to move the truck one way or another.   I just dropped the transmission in gear and let the truck idle to tighten the strap and the after all that fighting the tractor to the rear of the trailer just at idle the truck pulled the tractor off the trailer!  But it was also pulling his truck and trailer back too.  We got it off his trailer and I’m thinking what a t**d I had just had delivered to my house.
I got a crank from one of my WD-45s and tried to turn the engine over and it went a little less than a ¼ turn and stopped.  Water in the cylinder maybe, I’ll pull spark plugs today.   Not much good so far in this story but now for the dilemma.  I had a cordless belt sander and I cleaned up the serial number area on the rear of the tractor.   146762, wow that did not seem correct was I reading is correctly?  As it turns out this one is the 156th WD-45 made!  Most likely the first week of production in 1953?  I’ll pull the plugs today and try to turn over the engine again today and hopefully I will make the required 2+ full turns.
It seems sacrilegious to part it out, seems like it needs to be saved?   What does the forum think?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmarian Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 8:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmarian Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 8:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmarian Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 8:36am
Finally got the pictures up
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 9:49am
looks like a deal Bruce... If your using a cell phone, the phote self sizes.. For those of us using a computer, we need to shrink photos to  800 x 600 pixels or so to fit the page...
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 9:55am
Originally posted by bmarian bmarian wrote:
...tried to turn the engine over and it went a little less than a ¼ turn and stopped.  Water in the cylinder maybe, I’ll pull spark plugs today...
More likely a stuck valve. I would pull the valve cover and maybe the rocker assembly before any further attempt to rotate the engine.
The sheet metal looks pretty straight, I think it's a keeper Smile
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 3:39pm
Wow, I thought things didn't rust as bad in that part of the world.  That thing looks like it's been near the seashore.  Good luck with your projects whichever one you tackle first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmarian Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 4:43pm
Thank you all for the replies, I started just wanting the tractor for parts for my 57 Wide front tractor.  Now that I know is was likely the first week of production of the model that changes my thinking.  The toolbox, bottom of the oil bath air cleaner are rusted through but the left rear tire is not turning and that is causing the majority of the problems for me now.  I'll get the brake inspection cover off tomorrow and take a look there and I'll get the plugs out gently try to turn the engine over backwards then forwards.  I'm hoping for a stuck valve since that might be the cheapest fix.
I will spend some time over the long weekend working on the 53 if I manage to determine where I stand the next thing will be a set of tires and wheels.
Dennis the tractor is a long way from the seashore since I am East of Dallas, TX but who knows where it spent it's life.  I might need to come up to your neck of the woods to find a set of tires and wheels.  I might be able to fix the rear wheels but I need to get the tires off the wheels and take a better look.
Thanks for the replies,
Bruce
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 5:36pm
if your saving it because you want "one of the first" off the line, thats OK.... If your thinking of VALUE, i dont think the date or SN of a WD45 is going to make any difference in the long run.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmarian Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 6:26pm
Hi Steve, I agree unlike the serial number 0001 Corvettes that Rick Hendricks pays millions for at auction I doubt that I could get all the money back from the parts needed to restore this tractor.  If I do show the tractor some day it is a nice story, I wonder where there is a WD-45 that is older than mine.  It would be neat to have 2 real early WD-45s at the same show.
Hopefully, I will have more info this weekend and I will make a decision about how to proceed.
Thanks for your help,
Bruce
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 9:03pm
I came across a 52 WD with a serial number within two weeks of the WD we had on the farm I grew up with.
So I can appreciate your Number Chase!
evan austin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote evan austin Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 11:20pm
There is a guy I have seen on youtube, his channel is Tractor Dave. Anyway, he has the second WD45 off the line. 146608. He was planning to part out the tractor, until he checked the serial number. It's pretty rough, but he did decide to restore it rather than part it out. I don't think he has posted anything on it in a while, the last video I remember on it he was trying to get the engine apart as it was stuck really bad.
