Buying advice 6000/7000 |
ac160
Topic: Buying advice 6000/7000Posted: 27 Aug 2025 at 2:32pm |
I am looking into possibly purchasing another orange tractor as you can't have too many of them and need some opinions and advice. I am looking at another 6080, most likely 4wd or a 7000/7010. I know little to nothing about the 7000 series as a 6080 is my biggest tractor.
Background info...I currently have a kuhn discbine with 8ft cut that requires 60hp minimum, but if this one ever gives up I would have to replace it with a slight bigger one, 9ft that requires 70hp minimum as my model isn't made anymore. Currently I use a 6080 2wd on the discbine and in real heavy grass it knows it's back there. I also have a newer 70 hp 4wd of another color(not green) I could run on the discbine as well and think it could probably handle the 9ft. maybe? It doesn't have any issues with the 10ft brush hog in heavy grass/weeds. I cut around 85-100 acres of hay each year depending on the number of cuttings. If I went with a 6080 4wd I would put a loader on it for hauling bales and it would give me a second/backup 4wd tractor. Trying to find one in real good condition and lower hours will be hard and probably pricy. They are easy on fuel. The 7000 series would be cutting hay and brush hogging only. The cheaper option to buy at least, but not sure on the maintenance cost and fuel usage. A cab is neither here nor there for me so open station or turning the cab into a canopy is an option. How loud are they w/o a cab? What do you all think, should I be looking at another 6080 or a 7000 series? I don't have the shed space for both sadly.
Edited by ac160 - 27 Aug 2025 at 4:07pm |
DougG
Posted: 27 Aug 2025 at 6:29pm |
Id go 6080- they will do what your discribing, and very verstile than a 7000 series,,
ac160
Posted: 15 Sep 2025 at 10:44am |
Thanks. I figured they might be a litter more versatile and also take up less shed space.
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3631 |
Posted: 15 Sep 2025 at 12:29pm |
6080 fwa'S are slick units, rare, and keep in mind they do not turn very short so the maneuverability could be an issue.
Kenny L.
Posted: 15 Sep 2025 at 1:31pm |
Just a thought, If you're looking at a 6080 maybe also look at a 8010, I never own a 6080 but I sure love my 8030 and the 8010 is basely a 8030 with a 301 instead of a 426. You just have to have options.
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 716 |
Posted: 15 Sep 2025 at 1:53pm |
We had a 7040 that i thought was just as nimble as our 190s were We used it fir everything It was a powershift which slickened iup handling a lot.
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
DrAllis
Posted: 15 Sep 2025 at 2:01pm |
Without a doubt, there is a big gap between a 6080 and a 7010/8010 chassis. The 6080 2WD with no cab is 7600 lbs and the 7010-8010 are just about 12K lbs with a cab.
ac160
Posted: 15 Sep 2025 at 3:59pm |
Kenny thanks for the idea, I will have to take a look at the 8010 as well and compare.
Dr are you are talking just weight or all dimensions? The extra weight doesn't bother me so much, just the outside dimensions to make sure on shed space. I drive/travel/farm some hills so having weight for traction is a must. My 6080 has filled tires and a set of rear weights along with front weights for handling the discbine. Granted all my "main" tractors have fluid in the tires. That's a d17iv and up. My smaller ones just have rear weights or nothing unless they came with fluid in the tires. As tbran said 6080s fwa is hard to find especially a good one that wasn't abused. That's one of the other reason to look for a slightly larger tractor along with it being cheaper. I am going to look at a 7020 and 7060 a neighbor has to see what the cab is like on them and see what they say about them.
DrAllis
Posted: 15 Sep 2025 at 5:52pm |
You'll see what I mean when you stand next to a 7020/7060.
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3662 |
Posted: 15 Sep 2025 at 9:42pm |
7010 106 pto hp uses 6-7gall/hr fuel & 7020 124 pto hp uses 7-8g/hr fuel. Both share the 6 cylinder (301cu in) version of the 6080s 4 cylinder (200cu in) 83 pto hp uses 4-5gal/hr . So the 7010/7020s get a nice bump in hp & use a little more fuel.
The 7030,7040,7045,7050, 7060,7080 all use the bigger 6 cylinder (426cu in) diesel engine as follows; 7030 131pto hp using 8.5gal/hr, 7040 136pto hp using 9gal/hr, 7045 146pto hp using 10am/hr, 7050 156pto hp using 9.8gal/hr, 7060 160pto hp using 10gal/hr, 7080 181pto hp using 11.6g/hr. I sourced above info from tractordata.com Maybe visit that site to see others? Edited by AC7060IL - 15 Sep 2025 at 10:03pm |
977.3Ford
Joined: 04 Oct 2019 Location: Dayton, Ohio Points: 106 |
Posted: 15 Sep 2025 at 10:20pm |
Not quite the same but i've got a 6080 and a 8050. The 8050 is my planting/tillage tractor and i used to use it quite a bit in hay, but this year the 6080 has done all my hay and spraying work. The comfort and visibility of the 8050 is far better than the 6080, and it turns pretty tight, but just too big and cumbersome at times. We have a 4 basket tedder and a inline rake and with the 8050 you've really got to watch turning tight so you don't get the rear tires into them. When the ground is soft the 8050 leaves more tracks and tends to push more when turning tight too. The 8050 really shines on the discbine, we run a New Idea 5209 which pulls easy but the extra horsepower and powershift are nice in thick/wet conditions. Also, loaded on the road the 8050 feels lot more comfortable than the 6080. Between the extra weight and better brakes it handles going up and down hills a lot nicer.
Its really a shame Allis didnt have anything to fill in the gap between them.
Jimmy
1982 8050 Powershift 1982 6080 1992 R52 Gleaner |
joe
Joined: 30 Nov 2009 Location: SW Ontario Points: 167 |
Posted: 16 Sep 2025 at 9:23am |
Will a 6080 run a 9ft discbine as well as a 7010/7020. I'll say this. We've run a large square baler (Hesston 4755) with a 7020 for a few years. It gets the job done, but is a little short on power if any hills. I had the 7040 on it for around an hour for the first time, and it's a different animal. That thing has POWER, played with the baler. I'm quite sure it has M&W pistons, so that may make a difference. All that to say, it makes for a much nicer experience to actually have enough power.
ac160
Posted: 16 Sep 2025 at 2:04pm |
Dr I do see what you mean, the 7060 was very large compared to the 6080. It was a power director. At least it felt that way and the 8010 would be similar is my guess. I didn't get to see the 7020 as it was in the shop. The cab felt cramped compared to the 6080 cab, but quite usable.
I did look up the 8010 and it uses about 7.3gal/hr. So far, it sounds like a 6080 will do what I want albeit a bit slower and potentially will be harder on the tractor with a larger discbine, but fine with brushog. The 7000/10 and 8010 would handle w/o issues, but be a bit more cumbersome.
Edited by ac160 - 16 Sep 2025 at 2:05pm |
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1304 |
Posted: 17 Sep 2025 at 2:09pm |
I have no experience running a 6080.
But for what a 7000 sells for, maroon especially , I think it would pull circles around a 6080. Especially one with 38in rears. Yes the 6080 has a nicer cab. |
DrAllis
Posted: 17 Sep 2025 at 2:22pm |
Fuel consumption rating is at 100% load, not 50% load or anything less than 100%. Generally, less cubic inches is more efficient on lighter loads.
Kip-Utah
Joined: 14 Sep 2009 Location: Southern Utah Points: 921 |
Posted: 17 Sep 2025 at 3:28pm |
Hours, price, & overall condition should trump every other consideration
Rhoadesy_65
Joined: 28 Jul 2019 Location: Versailles, OH Points: 164 |
Posted: 22 Sep 2025 at 12:00pm |
We have a New Holland 1411 Discbine, I think its technically a 10 foot mower. I typically run it on the 7010 and it handles it real well. I have ran it on the 6080 before, and it still runs it well. You do feel it a little more back there. I will say that Idk what our 7010 would dino at, but last time the 6080 was at the dealership the guys put it on the dino and they had it going at 120hp. We got an 8010 this spring, and Dad wanted to plant with it instead of the 6080. I will say I prefer the 6080 for that, seems more nimble. The 8010 has a lot more cab space than the 7010. I feel pretty tight in the 7010, but the 8010 my brother and I were both in the cab at the same time comfortably while moving between hay fields this spring.
Farmin' with 1981 7010 PD, 1983 6080, 1983 8010, Gleaner R42 in Darke County OH
