Anti lock
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Anti lock
    Posted: 26 Aug 2025 at 9:32pm
brakes on ‘91 Ford F-350, the RABS module to be more specific. What is the proper way to ‘test’ that module?
The rear sensor on the differential shows 1600(ish) ohms, from I been told, that is acceptable?
So far, have not found the cause of the ‘Rear Antilock’ light constantly being on. If it went for the cruise control unable to activate, due to this particular warning light, I wouldn’t worry, but no cruise cuts into the mpg.
fjdrill View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote fjdrill Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 6:14am
Check Third cab roof Brake light. The cruise current runs thru that circuit--it's goofy, replaced two light bulbs there and CC resumed working. LED bulbs in that location will not work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 6:34am
Are you saying you have 'no cruise control'  ?
 If so ,was your truck recalled due to the 'master cylinder fire' problem and was 'fixed' by Ford ?
If so, then the fuse in the  'repair' has blown as the switch in the master cylinder has shorted to ground .
there is an EASY true fix to that problem that gives you back cruise control.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 8:22am
Didn’t know that. I will have to check it out. This truck has a topper on it, with no 3 rd light.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 8:41am
Thanks Jay, don’t know if this vehicle went thru any recall repairs. It appears the Master Cylinder is not original, wheather it was replaced by Ford or not, I don’t know. The fuse in the fuse panel(position #17) is good. Is there another fuse in this particular system?
Edited by Lars(wi) - 27 Aug 2025 at 9:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 11:07am
After further research, ‘91 F-350 was not equipped with the ‘3rd light’. That is the ‘cargo light’ that illuminates the bed.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote fjdrill Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 1:51pm
Yep! my bad. was thinking 3 Brake light was 91. It came in 94. They have given me grief till I figured them out. Actually, a buddy told me about it, and I thought he was nuts!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 1:58pm
My '97 was one of the ones with the 'flaming master cylinder' along with a long list of cars and other pickups. For that recall , Ford installed a small wiring 'harness' with an inline fuse. When that pops, no more cruise control ! Saves burning the truck toy  the ground( neighbours did is 10 minutes ! . Ned to see the wiring diagram, but for mine there's a 24/7 connection to the battery feeding the master cylinder switch that then powers the cruise control 'computer'. Dang silly 'engineering' and NOT needed....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 5:42pm
Speedometer MUST be Functional.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 7:21pm
Ever since the first fiasco (121 standard) ABS brakes they have been a nightmare.
Anything I've ever driven with some kind if ABS system, when in a pinch and your REALLY need to stop, the computer will say "brakes, you don't need no stinking brakes". I feel safer in my old vehicles that are pre ABS than anything new with anything ABS.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2025 at 12:59am
Been fighting with keeping these unsafe safety systems functional since inception in the 1970s on HD Trucks. All proved on Test Tracks until placed on the roadways and failed miserably. Trying to Safety fix all the bad drivers where all have done is made the average driver more complacent about Bad Habits.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 4:39pm
Update; got the dash light to go out, found the wires to the master cylinder brake fluid float were bad. But, with that remedied, the cruise still will not turn on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 4:45pm
Separate issue
This page was generated in 0.205 seconds.
