Antifreeze/coolant additive for diesels?
Rusty Allis View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rusty Allis Quote  Post ReplyReply Direct Link To This Post Topic: Antifreeze/coolant additive for diesels?
    Posted: 26 Aug 2025 at 8:27pm
It's been a million years since I've had to even think of this but here I am. Back in another life when I did diesel truck work, Ford had a coolant additive to prevent "micro bubbles" from basically acting like a ultrasonic cleaner and eroding piston liners (as I recall)
Anyhow, I've come into possession of a few diesels (one being a 5045) and all of the coolant tests at about 0*f for the freeze point across all the machines.
So the question is, is this additive even a "thing" anymore or is any old green coolant ok to run? Not really sure which way to go but want to get whatever is needed to do it right.
Thanks!
Edited by Rusty Allis - 26 Aug 2025 at 8:28pm
fjdrill View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote fjdrill Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 6:03am
YES!!     Napa has it, forgot the name but comes in a white bottle. I bought the last bunch in bulk off Ebay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 5:25pm
New Coolant has the Additive, HOWEVER, it is a Short Lived material so the Add Bottles for the Cavitation reduction, most commonly referred to as DCA.  NAPA, Ford here, sellers of Motorcraft Product lines should have it.  Generic is just DCA where can Google Search that as Diesel DCA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 7:33pm
Fleetguard makes the DCA additive available in small bottles.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rusty Allis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 8:56pm
Thanks guys! IS this the stuff?
Amazon.com: Cummins Filtration Fleetguard DCA60L Coolant Additive 16oz. DCA4 : Automotive
also, should I be getting test strips to figure out how much I need to add? Like I said, it's been a really long time since I've had to think about this. It's some of that information I flushed out to make room for something else haha
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2025 at 3:03pm
Nalcool  or similar spelling is what I use to get from truck parts supplier I did work for .
Seems mfg would send him many different samples and I would end up with some
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 5:03am
I use the test strips, reduces the chance of overloading the additive.
At Gelco leasing we used to add to the major fleet trucks at annual service interval regardless. That as the chemicals naturally deplete over tine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 12:04pm
Test strips only way to know where you are. Too much is as bad as too little.
This page was generated in 0.093 seconds.
