pusher bolts for 8010
pump grump View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote pump grump Quote  Post ReplyReply Direct Link To This Post Topic: pusher bolts for 8010
    Posted: 26 Aug 2025 at 8:58am
Does someone have or know where to get them ? I would make my own but can`t find the all thread that is the right threat . Thanks Steve.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 9:21am
Aren’t they the same as the 8030 50, and 70? if they are, you’ll find them in our shop. Got two coffee cans full of them.
Edited by Unit3 - 29 Aug 2025 at 9:06am
Northern Hoser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 4:17pm
Still available from Agco, 70265185 is the part number I believe. I bought a few myself.
Get some really good heavy wire brush bits for a power drill to clean the threads out of the wedges. Threads will have to be in good shape
Matt.
Edited by Northern Hoser - 26 Aug 2025 at 4:19pm
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 7:36pm
Are they the same as for AC 200, 7000, 7010, 7020.?
The picture attached in here looks like they could be.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 9:24pm
7010 and 7020 use the same bolts. 200 and 7000 use the smaller bolts.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 10:04pm
www.awtractor.com
A&W TRACTOR 920-598-1287
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 2:36pm
All thread would just destroy itself.  It's nowhere near strong enough to do anything.  You need grade 8 (at minimum) bolts to break the centers loose.  They are also an unusual thread pitch.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote pump grump Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 10:12pm
There is different grade of all thread  and yes it is a odd thread pitch , I can`t find a tap either .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 9:11am
Pump Grump I have been trying to get back to you, but I haven't been able to get on here for a few days. Did you receive my message yet?
