Front end loader quick attach?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Front end loader quick attach?
    Posted: 25 Aug 2025 at 7:28pm
I have a White 1610 front end loader on my 175. I want to add a quick attach bracket or lift bracket to pick up loader bucket. Want to use forks some. I can't find the place that had the best looking ones..... I thought it was Iowa implement or something similar. Any help appreciated. Tracy
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 8:10pm
Look into Worksaver, they are a couple miles down the road from me in Litchfield Illinois. American made and lots of good quality attachments and adapters for tractors and skid steers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 10:23pm
I checked out Worksaver, they are not the ones I remembered. Thanks, Tracy
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 5:38am
Westendorf has a quick tach system.  Works, but not the best.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 6:39am
MDS, has a style that you use your pivot pins.  Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 6:19pm
I have searched and searched. Can't find the place that had them. They really looked well built and at a good price. They even had a form to fill out that took measurements from your front end loader. I hope to find them. Tracy
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2025 at 8:35pm
AaronSEIA
I personally like the Westendorf setup and it’s what I run. I like it much better than the skid steer attaching system, which seems to be rapidly becoming the standard.
Only down side is you usually have to modify any attachment you but as it’s likely already setup for skid steer. Also, even a lot of times if the attachment you are buying already has a the Westendorf hookup the width spacing will be off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 12:19am
I saw a Bushhog 2400 today with their early style of quick attach. Looked pretty slick. I may try that on my loader. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 8:36pm
I found a guy about 2 hours from here that makes some nice looking units. Might give them a try. Bell precision in Shelbyville, TN. Thanks, Tracy
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2025 at 12:39pm
I always wanted to take the curved fast hitch hooks off a f combine bolt to my bucket and build my quick change from there it would be extremely easy to match up when mounting an attachment
This page was generated in 0.119 seconds.
