D-17 rated engine speed?
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Topic: D-17 rated engine speed?
    Posted: 23 Aug 2025 at 7:10pm
Were all series of D-17's engine speed rated @ 1650 RPM? What were the 170's and 175's rated at? I know the 226 Gleaner engines were faster but what were they rated at? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2025 at 7:29pm
D-17 and Gleaner model "E" combines were rated load at 1650 RPM.  D-17 high idle no-load was 1950-2000 RPM. The Gleaner engine i think was 1850 no-load.  All 170-175 gas engines were rated load of 1800 RPM and high idle of 2000 to 2025 RPM.  All three of these applications have their own specific governor weights and springs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2025 at 7:23am
Thanks Dr., my D-17 series IV is low at 1500 +/-. What needs to be don e to get it up to speed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2025 at 7:54am
Wide open throttle no load should be 2000 RPM for a D-17 tractor. What are you checking the speed with?? Hard to imagine it is that slow, unless it has the wrong governor spring installed in it. Nevertheless, there is linkage under the gas tank that may have an issue or simply needs to be adjusted to pull the long rod (to the engine) back farther. There is a max speed screw located vertically on the governor spring cover that could be adjusted upward to the max setting, but that usually only gains 75 to 100 RPM max. The long throttle rod from under the gas tank to the engine should be able to pull the governor lever arm on the engine back to where it hits the timing cover or about the 10:30 o'clock position for max speed. *** Just a note about engine speeds: With high idle (no load) at 1950 to 2000 RPM, the "rated load" speed of 1650 RPM is when you have lugged the engine down to that "rated" speed from the high idle no load speed. It is where the manufacturer makes a claim of 63 flywheel HP (53 PTO HP) @ 1650 Rated RPM.
Edited by DrAllis - 24 Aug 2025 at 11:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2025 at 10:30pm
Make sure there aren't ANY springs on the governor to carb linkage on the LEFT side of the engine. NONE.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 8:21pm
The Doc really hates dem dar springs with a passion. I don't remember seeing a spring there on a D-17 but have on WDs and Bs & Cs. I think there might be a little room for debate on their effectiveness on the Bs and Cs. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 8:59pm
The problem on some WD/WD45/D17's is the CHOKE spring gets hooked to the throttle lever (by mistake) causing terrible negative things to happen to governor performance. Henceforth NO SPRINGS has to be enforced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 9:01pm
And like with many posts the O.P. was on here 14 hrs ago and has never told us what was wrong.
