ca hand clutch
rilenz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilenz Quote  Post ReplyReply Direct Link To This Post Topic: ca hand clutch
    Posted: 22 Aug 2025 at 7:05am
Hi fellow Allis people. Haven't been on here in a while but read everyday. ? I rebuilt my hand clutch recently. I now have a squealing noise when I pull the handle in and when I release the clutch grabs hard. Any thoughts?
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2025 at 9:57am
Bad release bearing?  :(
Edit:  As far as grabbing hard, I think that is fairly normal.  I was never able to get to engage gradually at least not easily.  I don't think you have enough control with the lever arm as it is.
Edited by dfwallis - 22 Aug 2025 at 4:54pm
1952 CA13092
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2025 at 6:02pm
A friend of mine would like to have his hand clutch rebuilt. Is anyone doing them since Rick Corder quit doing clutches?
CA13414 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2025 at 6:39pm
We also rebuilt our hand clutch. You will find the post about half way down on page 11.
Rebuilding was not difficult. After, there was no slipping, but it also grabs hard. I can release and re-engage slowly and the grab is better. If not, it is quite a snap and "lurch!"
I bought a rebuilt clutch plate, springs and a bearing from SandyLake implement. Was easy to do and works well
Dan
Edited by CA13414 - 22 Aug 2025 at 6:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2025 at 6:47pm
I took mine to the local "former" AGCO dealer (Brownstown, Indiana).  He'll attempt just about anything.  I was going to do it, but I wasn't immediately having luck finding a puller long enough and my trip was coming to an end.  I actually found just the right tool on my next trip.  I gave him the liners, rivets, and a rivet tool to use.  He didn't actually have the rivet tool any more.  I took only the axle.  I reconditioned the bearing myself.  It was locked solid from many decades of disuse.  I removed all the gunk and re-packed it with grease.  I took it to him to check over and he said it was almost like new, so I put it back in.  It's working good so far (6 months).
Edited by dfwallis - 22 Aug 2025 at 6:54pm
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2025 at 7:11pm
 I have done dozens of the CA axle clutches over the years. Contrary to popular belief, I can make them hold more torque than the factory engine clutch can transmit.
 However the parts for them keep getting more and more expensive. The only way I would accept one to rebuild would be time & materials, with a healthy deposit up front.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2025 at 7:30am
I have two ca's, both have belly mowers, one at each farm. One of them, the hand clutch does grab pretty hard. To remedy this, I put the tractor in fourth gear at about 1/3 idle pull the hand clutch back then release the foot clutch. Now slowly release hand clutch until it begins to slip and pull the engine down a bit. This seems to clean the clutch plate up and does not grab nearly as bad.
Leon B Mo
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilenz Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2025 at 8:16am
Thanks for the advise. I'll check into the release bearing and try the 4th gear slip method.
