706b engine transplant
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Topic: 706b engine transplant
    Posted: 20 Aug 2025 at 6:06pm
I recently purchased a 706b forklift. It runs and has enough power but it has so much blowby it pushing oil out the dipstick tube. Its my understanding the later models had a 433 allis engine. Mine has a perkins. My question is if a 433 could be transplanted into it and what it would entail
Thanks in advance
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2025 at 11:27am
I just bought a 706B that was repowered from the Perkins gas to a 4bt Cummins, I would have preferred the 433T but the price was right and it was close by.
Doesn't look like it was a lot of work, but be careful you get the engine mounts exact, because whoever did this conversion didn't have it exact and it broke every engine mount in the frame
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2025 at 5:20pm
Thanks for the reply. Im mostly concerned about the adapter plate for the bell housing. I think i can get by with this engine. Its git a skip on one cylinder and it will fire on that cylinder every once in a while. The cause is an injector leaking compression. I didnt catch the sound of the injector because the exhaust manifold is broke. When i fix the injector i think it will run fine. I slowed down the oil blowing out with some lucas oil stabilizer
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2025 at 7:25am
the tranny/torque converter looks like it bolted right to the engine, and I am assuming because Perkins, Allis, and Cummins have a ASAE standard bolt pattern, but I don't know about the actual converter bolting to the flywheel, I cant see that part.
Perkins parts are pretty easily obtained, might just be simpler and cheaper to just fix it, the job they did on mine isn't real clean, so we are in the process of finishing it right.
ac-mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac-mike Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2025 at 8:22am
I have a 706 with a diesel engine out of an 800 Ford. I believe it came out with the gas version of that engine.
D-12III, 200D, 170G, HD-3, D19D 3pt, D17D High Crop, WD45G p/s, D15IID, D15IIG, D15G IND, 655, (3)WD45D p/s, 700, 816
