Radiator and Electrolysis
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: Radiator and Electrolysis
    Posted: 14 Nov 2010 at 12:53pm
Will it damage the copper and solder?
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 1:06pm
I wouldn't think so.... maybe try a heater core first ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 2:53pm
suppose to attack rust (iron oxide). Stops working when the rust is gone. Not suppose to attack clean metal, copper, lead.
Bertman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bertman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 3:35pm
Dont think it matters if its steel, copper or whatever. I work in a radiator shop and if you boil it out you remove some of the apparent metal. Radiators only have tubes that are .005 (thousands) thick. Add years of service and you can make a pin cushion. Sometimes the only thing keeping it from leaking is the mud or stopleak in it.
I think 1 ton of steel turn into 3 tons of rust but thats useless trivia
Edited by Bertman - 14 Nov 2010 at 3:36pm
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 4:40pm
 It may or may not brighten the exterior of your rad but inside as Bertman sez, it won't do anything for you; the mud ,stopleak and gobs of excess silicone gasket maker will still be there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 7:03pm
I have gotten junk out of a radiator by running water and compressed air at the same time through it. If it's full of stop leak, you'll probably be opening a can of trouble...
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 7:52pm
Just want to remove paint and rust from the bottom.  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2010 at 12:09pm
If it's just trying to remove stuff from the outside, I think it ought to work well. Seems like for it to work, the part to be cleaned has to be between the 2 electrodes.
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2010 at 11:21am
Don't leave non-ferrous metals in too long!!
