My New Toy
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: My New Toy
    Posted: 18 Aug 2025 at 6:02pm
Got a 9 inch South Bend lathe that i inherited from my dad 30 years ago. Gramps use to run it at the war factory in 1942... Dad rebuilt it in 1980.
15 years ago i bought an old RYERSON that was to be scrapped and rebuilt (repaired) it... 1895 vintage, 22 inch swing.. Yea its a horse and clumsy but gets you within a couple thousandths.. ( it will be retired when the 16 inch lathe is finished)
Been looking for a South Bend 16 inch short bed for quite a while. Ran accross this one on Marketplace.. Had to drive 2.5 hours to get it... 1952 model so its NEW compared to what i own. Dirty, but everything seems to be TIGHT... 3 phase 1.5 HP motor so i need to get a VDF or new single phase 1750 rpm motor..... Going to be a winter ( Jan- Feb) project... Tear down , clean, inspect, new belts, maybe bearings... and PAINT.
And the straps on the chuck shaft are not TIGHT... just keeping it from tipping over... Straps around the bed for anchor.
Edited by steve(ill) - 18 Aug 2025 at 6:20pm
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2025 at 6:58pm
Ah yes, the old belt drive Southbend. We had 4 or 5 at my high school. Mr Dye loved them because if you hit chuck hard enough to break the belt all you needed was a stapler
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2025 at 7:47pm
just looked and this one has the taper cut adaptor on the back.. I never really notice that when purchase... also the leather belt is GONE... has a 2.25 inch wide rubber belt with knobs on it, turned inside out so it runs on the SMOOTH SIDE rubber..
similar to a serpentine, but cogs..
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2025 at 9:42pm
The ones with motor in the basement were called underdrives.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2025 at 9:56pm
YEP... motor in the lower cabinet came in the late 1940s.... Before that the motor and reduction shaft were mounted OUT BACK....... Lathes from 1800- 1930 era had TOP MOUNT as they were hold overs from the old ROOF MOUNTED pulley/ shafts from the steam engine days....
This is my 1895 Ryerson with the "UPDATED" top mount beam , motor and reduction shaft.. Original was probably ROOF driven in a big factory..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2025 at 10:02pm
https://www.youtube.com/watch?v=cXDbH5pzagc
7 minute mark shows a good view.
Edited by steve(ill) - 18 Aug 2025 at 10:04pm
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2025 at 5:57am
Steve that’s a good looking machine.
Of course your old one is a good looking old beast as well.
Can’t wait to see this one finished.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2025 at 9:04am
got it setting outside the garage door right now.. Spend a couple days cleaning the crud off before moving inside....... guess the first thing i need to do is get a VFD and temp wire so i can test it out and see any potential problems..... guy had 3 phase power and started the motor up , engaged carriage and moved 6 inches.... about 1 minute run time is all i got.. rubber belt is spiced with steel aligator clamp... i could hear that BUMB- BUMP as it ran....... winter project, but need to run an hour prior to that to test EVERYTHING out, before teardown.... got to have a base line for work.
