AC 720 with Arc loader. Add float?
Heliarc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heliarc Quote  Post ReplyReply Direct Link To This Post Topic: AC 720 with Arc loader. Add float?
    Posted: 18 Aug 2025 at 6:45am
AC 720 with an Arc 700 front end loader. 2 stick control and it doesn't have a float. I'm not opposed to plumbing in a single stick control if I could find a decent used one with a float. I've read about a valve between the pressure lines for lift and lower as well, open that when you want to float. My hands are busy enough with steering and working the hydrostat control and then two sticks on the loader. It does the job but it's not ideal. If I could at least have some kind of float for certain things it would take some of the mental effort off.
Anyone done this in the expedient fashion with a valve between the pressure lines and/or by plumbing in a single stick controller from another machine?
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 6:33pm
Search for hydraulic valves with return to float. ~ Orangeman
This page was generated in 0.043 seconds.
