Clutch Carnage
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: Clutch Carnage
    Posted: 17 Aug 2025 at 4:52pm
Self inflicted, of course Cry
I just hate when I do dumb things Embarrassed
We recently got the derelict Model C assembled enough to try to see if it would make some noise. The B-125 combine engine was stuck so we pulled the head and pan, got it freed up and did a basic valve job, we did not pull the pistons nor did we remove any bearing caps.
Hand cranking resulted in no joy, and hand cranking to check compression showed VERY low compression, less than 45 psi on cylinders #1 & #4, less than 10 psi on #2 & #3.
We then connected the derelict Model C to my other Model C via the flat belt pulleys, gave it a whirl and it fired right up!
I immediately shoved the clutch forward to disconnect the tractors, trouble is, there was excessive looseness in the clutch pedal and the pedal slipped right past the physical stop on the torque tube, thus allowing the clutch rod to slam forward into the clutch fingers, instantly breaking them off of the pressure plate.
Besides the obvious looseness in the clutch pedal, which I have since fixed by drilling out the holes and installing an oversize clutch pedal shaft, the clutch operating rod was too long, a previous owner having lengthened it by welding a bolt in it. I had to cut off about 5/8" to get it back to the correct length.
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 5:59pm
Don't you just love life lessons....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 7:07pm
Yup! Smile
I am probably the only person on the planet to have ever put this particular combination of errors together to create this problem in the past 80 years Embarrassed
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 7:55pm
That is the best story that we have heard here recently! Will make for some good laughs for your next shop get together! Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 8:29pm
Normally the comments are "YEP... Been there Done that"........ but this time i think YOU got a Cherry !!  Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 9:24pm
Yup Tongue
On Page B-C - 30 of the shop manual it reads "Usually one or two threads extend through the yoke screw when properly adjusted. Make sure the clutch pedal strikes stop on side of torque tube."
My 14 year old Grandson is my partner in grime on these projects; I told him that sometimes it is good to know how NOT to do things Tongue
Jay Tee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Tee Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2025 at 9:23pm
That must have made a really interesting bunch of noises when it happened. Ouch!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2025 at 11:05pm
It all happened so quickly I don't actually recall hearing anything but the roar of the stubby straight pipe exhaust; we didn't plan on running it very long (no coolant) so the muffler was left off.
My grandson said that I looked rather perplexed for a bit though Embarrassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 8:29am
Grandson and I took another stab at firing up the derelict tractor yesterday. On the first try I forgot to remove the grounding wire I had attached to the magneto but that did allow sufficient cranking to show good oil pressure.
After removing the kill wire we spun it again (using the flat belt pulley connection) and it fired up but wouldn't keep running on its own so we just kept spinning it with the flat belt hoping to develop some compression.
We had filled the radiator with water so no worries about cooling. We let it spin for about ten minutes but it never would keep running without the additional help of the other tractor. The engine did warm up slightly but nowhere near a normal condition.
We then stopped and pulled the spark plugs, all looked good there. Pulling the valve cover revealed good tappet clearance all around.
We then did a compression test while spinning with the flat belt #1-115, #2-80, #3-112, #4-113. Not too bad all things considered, and certainly good enough to keep running even with that weak #2 cylinder. Cranking speed makes a huge difference, I couldn't get over ~45 psi while hand cranking.
The next thing we checked was the spark and timing. The timing was still good, but this Wico magneto, which had been sparking just fine last winter when I installed it, now only showed a feeble spark on #4 and none on the other plugs; it probably just needs the points cleaned again but we swapped in a spare Fairbanks-Morse unit and gave it another whirl.
This time it fired right up and kept right on running all by itself! Lo and behold, these engines do need good ignition Tongue Who'da thunk it! LOL
It was getting late and it was time to do chores so we quit for the day; there are still lots of small details to address but we are quite happy with our success thus far.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 8:49am
i have several small tractors and have " cleaned and new parts" in the mags over the past 20 years ... had a stubborn one 2 years ago... bought a "REBUILT" from a vendor on this site... WOW... Takes off on one revolution and NEVER misses a beat.... YEP.. The MAGS are great when you got a GOOD ONE !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 4:11pm
Grandson taking the tractor for a test drive
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 6:52pm
Theres something about saving a old tractor or other equipment that gives a special satisfaction. A big smile on a grandchilds face is priceless. Battle scars and broken parts from mistakes or whatever are part of the process.
Good work
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 7:55pm
The only person who doesn't make mistakes is the person who never does anything.
I don't care what direction your grandson goes off in; he will always remember this event as a happy moment in his life!
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 9:49pm
Watch out for tree branches with that exhaust pipe LOL
Pretty cool to see it out and about.
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 10:03pm
Dang the foot clutch on my WD goes well past the stop... Clearly had for many years before it came to me. Am I just lucky the clutch didn't ever bust on me?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2025 at 7:14am
I have never been inside a WD  but the Model C certainly doesn't like the combination of non-functional stop plus extended clutch rod Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2025 at 7:19am
Yup!
The exhaust manifold has a short stub welded on it so I simply plunked the extension on it from the combine engine. Not a good long-term solution in our timberland Big smile
