WD stuck in 3rd or 4th |
jmrehn
Topic: WD stuck in 3rd or 4thPosted: 13 Aug 2025 at 12:09pm |
I have the shift lever out, looking in I can easily see things are misaligned,Can not get any movement pushing things around in there. Tried it with a real wheel jacked up and rocking the wheel while trying to realign the forks, no luck. So, I am going in to remove the shift tower. A video I watched on this shows removal of the steering post,levers and all attached to it.
My Question is this necessary? can I just remove the bolts holding the steering post, and shift to the side to clear? Probably support it all from above? |
53WD
DrAllis
Posted: 13 Aug 2025 at 12:31pm |
A long flat blade tip screwdriver is what you need to pop things back into neutral. You can only move ONE shift pocket/lug at a time.
jmrehn
Posted: 13 Aug 2025 at 12:40pm |
I can get no movement at all trying that way. Going out now to give it another try.
Edited by jmrehn - 13 Aug 2025 at 12:42pm |
53WD
DrAllis
Posted: 13 Aug 2025 at 1:01pm |
Smack your screwdriver handle forwards or backwards with the tip engaged in ONE slot inside.
jmrehn
Posted: 13 Aug 2025 at 2:10pm |
Got it,a little more force was necessary, thank you Dr.Allis
53WD
