Hand crank pin
Phil Stier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil Stier Quote  Post ReplyReply Direct Link To This Post Topic: Hand crank pin
    Posted: 09 Aug 2025 at 4:25pm
I’m looking for the pin in the hand crank shaft that engages the engine front pulley on a WD
What is the size and nomenclature for the pin. Is it tapered ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2025 at 8:50pm
Certainly not tapered. I think a common 5/16" roll pin about 2 to 2 1/2" long is what it takes. It could be 3/8" diameter but anyway, it is a very common size. Too short and it doesn't engage the jaws well. Too long and it won't go into the jaws.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2025 at 11:33pm
It is a common roll pin....hardware store or farm store
Edited by SteveM C/IL - 09 Aug 2025 at 11:33pm
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2025 at 1:03am
I think the one in my WD was just solid round stock, but no clue if it was original or not. It was sure stuck in there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2025 at 6:17am
The original was a solid pin and many have been changed to a roll pin just because of the difficult removal.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2025 at 9:04am
Originally it was a round stock probably put in cold when the crank was hot it didnt come out. I replaced mine with 5/16" round stock 2 1/4" long and tack welded in place
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2025 at 10:39am
My WD45 had a solid dowel pin. 3/8x2.5"
I have a whole box of them here. I couldn't find just one pin and had to buy a box when I put mine back together
Lawffeg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lawffeg Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2025 at 11:32am
This page was generated in 0.168 seconds.
