Bowed front axle WD/WD45 |
Post Reply ![]() |
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29802 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Aug 2025 at 9:15am |
I just bought a wide front at an auction with the center channel slightly bent. Any suggestions on how I might bend it back. Will a good size press to it? My press is too narrow but was thinking of using a 20 ton jack, an HD11 dozer and some steel plates and blocks. Another thought was to cut the curved braces off and then straighten then weld back together. Second option doesn't look easy. Anyone else have success straightening one? Thanks
Wink I am a Russian Bot |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21779 |
Bent downward in the center ?? from an overload with the wheel tread set wide ??
Yes that's what it looks like.
The axles weren't set wide when I bought it. Just one hole showing and with some snoose juice and some tapping with a maul they came out. Wasn't bad to get them out.
Edited by Lonn - 08 Aug 2025 at 9:26am |
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5073 |
Chain it down out by the spindles on your trailer and use a 20 ton jack at the point it looks to be bent down.
To add to that, I'd have a 1" thick plate about 6 inches square to place between the bottle jack screw and the axle tube and see how close you can get it back to straight. To finish one might be down to 3 inches long to over bend it so it can spring back.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8590 |
Isn't that a tube with the bottom partially cut out? Might want to tack a couple chunks over the slot to keep it somewhat square whe bending back. The metal is stretched so I doubt you can straiten it well. My opinion....
Thanks folks I'll take all the advise into account and let you all know how it goes.
cwhit ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Sigel IL Points: 992 |
Another idea, do you have a friend that has a body shop? Frame straightener can true it up. Seen it done.
https://www.facebook.com/share/p/16x8P5DedR/
Edited by Lonn - 08 Aug 2025 at 6:31pm |
Heated to about 200 F just to relieve the metal.
Link didn't go to my fb page so hopefully now it does
Nope still doesn't I can't post pics from my phone.... says file size is too large Edited by Lonn - 08 Aug 2025 at 6:34pm |
![]() ![]() ![]() Edited by Lonn - 08 Aug 2025 at 8:57pm |
Post Reply ![]() |
