Pole barn questions
Greg(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Pole barn questions
    Posted: 04 Aug 2025 at 4:14pm
I was wondering if any users have experience with pole barns.  Trying to stabilize a pole barn where half of it is like a lean to off the old dairy barn.  The front of shed is regular full trusses.  The back half is made up of half trusses that are attached to the barn.  The barn is not structurally sound and need to do something.  Those six back trusses do not have poles and are only attached to the side of the barn wall.  My plan is to laminate 2x6s to make poles on the side attached to the barn where the long end of the truss would be laminated into the pole.  The bottom of the new poles would be attached to the concrete floor using some metal brackets.  All the poles would then be braced and could remove the rest of the old barn and then close in that side with tin?  Wondering if this is a sound plan or if there were other ideas.
Edited by Greg(WI) - 04 Aug 2025 at 4:44pm
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 4:28pm
Our pole barn is a 40x60 straight open barn with posts on 12ft centers and trusses on 5ft centers. Top pitch is 5/12 and bottom is 2/12. Ours is braced with 2x6s in an L shape running the length of the barn about 3 feet below the truss bottoms. Then we took 2x6s on a 45 from the L shape to the side of the trusses. Braced ours side to side and laterally very well. We've had a few cases of 60+ winds and it's still standing
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 5:43pm
seems like you have HALF TRUSSES attached to the outside wall of the old barn.. making this a lean to... YES.. if you make posts out of laminated 2 x 6 and set one at each truss and attach at the bottom and top of the truss to the post, you will make a TEE out of it which is exactly what you want from an Engineering point of view... Pinning to the concrete at the base should be fine. No need to drill and bury the post.
TavinLocke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TavinLocke Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2025 at 3:37am
Your bracing plan sounds solid—adding laminated 2×6 poles with triangulated bracing definitely strengthens the structure. It’s like Provably Fair Blackjack, where every shuffle is independently verifiable—building trust in the outcome, much like building trust in your structure.
Edited by TavinLocke - 29 Aug 2025 at 7:14am
