wd45 power steering reservoir gasket
sling-it View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sling-it Quote  Post ReplyReply Direct Link To This Post Topic: wd45 power steering reservoir gasket
    Posted: 04 Aug 2025 at 8:03am
I've got a Char-Lynn power steering pump on my WD45, and the darn thing simply will not seal.  Does anyone have a source for the rubber gasket for the lid?  I tried cork, but it won't quit leaking until it gets about half empty.  It's roughly 5 1/2 in diameter, and I just don't know where to look for it, and I've got a feeling cutting one myself is just another recipe for failure
Edited by sling-it - 04 Aug 2025 at 8:06am
albatros_3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote albatros_3 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 10:52am
I had the same problem with the resevour on my system. I added some gasket maker to both sides of the cork gasket and that fixed that leak.
Post Options Post Options   Thanks (1) Thanks(1)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 3:25pm
Get a new rubber gasket from Stiener for a 600-800 Ford with the Eaton PS Pump it will be the same.
