go carts
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: go carts
    Posted: 03 Aug 2025 at 5:45pm
Oh, mighty well of knowledge...
..why don't gocarts have differentials ? Next door bought 2 hand they have solid axles....
just curious....
Jay
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2025 at 7:23pm
Cost I guess? Plus wouldn't their be a need for more HP to turn a differential rather than a centrifugal clutch? And maybe a transmission or at least gear box of some sort?
Edited by thendrix - 03 Aug 2025 at 7:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2025 at 7:24pm
Like Henry Ford said. If I can make it cheaper and people will still buy it, all that much more profit for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2025 at 7:37pm
too much HP for one wheel.... need the traction of 2 tires... slide thru the corners anyway... dont want the additionaal weight..
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2025 at 7:53pm
Steve is right.  Usually two much HP for one wheel.  I raced them back when i was a teen and still build them occasionally.  My Grandsons each have one here on the farm.  I took one for a ride when I first built them.  Never again!!  Too fast for me at my age!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 5:38am
thanks guys ! I KNEW asked the right guys !!
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 7:49pm
No race car has diff. At least not conventional diff. Low budget guys weld them up. Or you use a spool to tie both axles together. Diff is there only to transfer the power and get the right rpm on each track. So we change the diff for each different track. Most guys have a dozen or so Ford nine inch in the hauler. Or you use a quick change if allowed. Then you just have to change two small spur gears- bout 5 min deal. You would just smoke one wheel with a regular diff.
Edited by Ed (Ont) - 04 Aug 2025 at 7:51pm
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 10:28pm
Can't drift with a one wheel wonder and tear up as much yard. Oh does that bring back memories of the original Honda Odyssey's back in the day, had one second hand for a short stint then traded it for a demo car oh to be young again and know half the stuff I know now. But the demo cars were as much fun building as they were running.
