Briggs model NP remote throttle linkage |
Heliarc
Joined: 23 Jun 2019 Location: Shickshinny PA Points: 74 |
Topic: Briggs model NP remote throttle linkagePosted: 03 Aug 2025 at 5:11pm |
Working on a Bolens 12B walk behind tractor. I believe it's a power ho but not 100%. Someone was in to it and between the throttle bell crank and the wind vane governor, something is missing or not hooked up. It's set up for a remote throttle control via cable to the handlebar. I'd like to at least set it up for the customer that it's constantly at a decent RPM but using the governor so he's not tempted to bypass the governor and rev the guts out of it. Anyone have a decent pic of how the linkage between throttle and governor ought to be? Whatever setup you have I can probably make something work. I just want to make sure the engine will be OK before I let it go.
Edited by Heliarc - 03 Aug 2025 at 5:12pm |
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 10 Aug 2025 at 8:21am |
I have a Bolens walk behind here---not sure the model. its back in the shed behind the tb tillers.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90812 |
Posted: 10 Aug 2025 at 1:07pm |
every small engine should have a hard link to the governor arm... and a spring to set the governed RPM....
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25255 |
Posted: 10 Aug 2025 at 1:22pm |
might be the engine " Looks like Noah brought it over ! |
