8010 power director
PawPaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PawPaw Quote  Post ReplyReply Direct Link To This Post Topic: 8010 power director
    Posted: 03 Aug 2025 at 2:53pm
I had trouble with the 8010 this spring planting no high side on the power director finished planting with backup tractor and just getting back to fixing it. When I shift up it blows the 15a hyd. alt fuse. I have checked the wiring and kick down switch on the clutch and found nothing wrong. Checked solenoid and got 1.3 ohms which I would guess is very low, with the solenoid disconnected I can upshift without blowing the fuse. The solenoid is NLA. I haven’t called about a salvage and was wondering what normal ohm reading should be to make sure I don’t by one like I have. Any tips or suggestions greatly appreciated. Thank you
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2025 at 4:41pm
Google says a typical solenoid has a resistance of 20-40 ohms.
I'd guess yours is shorting out, as you pretty much proved by not blowing the fuse when you disconnected the wiring from the solenoid and didn't blow the fuse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PawPaw Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 3:09pm
Found a new solenoid at Heitman tractor. They said they had 3-4 left and when they’re gone that’s it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 6:10pm
Awe theres gotta be more out there, Allis shopped just like everyone else- new Allis parts show up on Ebay every week,,
Edited by DougG - 04 Aug 2025 at 6:12pm
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 9:23pm
There's likely a brand name and Mfg parts number on the solenoid. Probably can't read it on a 40+ year old that's been in use, but those news ones should have readable numbers.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 8:24am
If memory serves correct the early power director spool/coil assy was replaced with a coil and spool that were 2 piece. The latter coil is available. part # 79028135
Post Options Post Options   Thanks (0) Thanks(0)   Quote PawPaw Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 10:54am
You are correct but they are not interchangeable
Post Options Post Options   Thanks (0) Thanks(0)   Quote PawPaw Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 11:14am
The one for early serial numbers has 2 prongs that plug in 1 black and 1 white and goes in from the bottom up. The newer one looks to go in from the top and I believe has 3 wires.
When the new one gets here and I get it changed I will check for part numbers on both of them and post.
Someone may be able to cross numbers to find what CNH part is the same.
I didn’t put 2&2 together till now but the tractor would drain the battery from time to time if it wasn’t used for a while and I couldn’t find the cause so just started disconnecting battery cable if it wasn’t going to be used for a while. I’m betting the solenoid was the cause.
BrianP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianP Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2025 at 8:37pm
Dad & I bought an 8070 about 10 yrs ago with a bad power director solenoid. it was the earlier solenoid & the coil was NLA. We found Santa Fe Coil online & had a replcement coil made. Not cheap but out tractor went from a 10 speed back to a 20 speed. We have not had any problems for the last 10 years with it
Post Options Post Options   Thanks (0) Thanks(0)   Quote PawPaw Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2025 at 11:46am
Well some progress. The new coil is on and the plunger on the solenoid goes up when I shift to high but drifts down and there is no response from tractor when I shift. The old coil had a melted spot on it so it was at least part of the problem. Not sure what to try or look at next. Any suggestions on what to try next? It doesn’t blow fuses now. I got some numbers off of both coils and will post when I get back to the shed. Thanks for any ideas on what to look at next
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2025 at 10:27pm
Check the voltage on the power wire, sounds like something could be faulty. Either the wire itself or the switch.
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote PawPaw Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2025 at 7:00pm
Well we got it figured out this afternoon. The problem was a loose connection where harness plugs into the short pigtail that goes to the solenoid. Still need to get the leak fixed that causes the oil on the solenoid plunger. I suppose that could be what took the coil out.
I got what numbers were readable off of the old coil
      178068 ? v
       10 VDC
       E76896    PMC B
   I got this off of the new one
    Waterman
    19??
     C1118
Hope these are of use if someone else needs one. I put what I had in a search and didn’t find anything like it. Did find a bunch of Waterman coils but non like I needed. Thank you all for your help
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2025 at 10:59pm
Thanks for the fix follow up!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2025 at 5:38pm
Yes !!!! Thank you for the follow up - I hate electrical problems,,
This page was generated in 0.949 seconds.
