7040 hydraulic coupler tip ??
INAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote INAllis Quote  Post ReplyReply Direct Link To This Post Topic: 7040 hydraulic coupler tip ??
    Posted: 02 Aug 2025 at 7:13pm
New to me piece of equipment needs different hydraulic coupler (tips) can someone give me a parts numer or reference #, the male end that fits into tractor outlets to replace the balers current JD tips?? TIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2025 at 7:19pm
Common Pioneer BALL type tips.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2025 at 10:12pm
The original were not pioneer but drawing a blank on the brand. I think bruning. Pioneer will work as long as the implement doesn't spike back pressure. like a disk flopping over against the cyl. That will cause the pioneer tip to seat the check ball. Cycle lever in opposite direction to release and continue. pioneer will work just that case may give a little trouble
Post Options Post Options   Thanks (0) Thanks(0)   Quote INAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2025 at 2:56am
Thanks, reason I was asking bought 4 at TSC that appear the be identical but I have absolutely zero hydraulic function to baler regardless of which set outlets etc
Very frustrating I'll push on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2025 at 7:00am
When you raise or lower with each remote hydraulic lever you should be able to hear the hydraulic pump groaning ....
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2025 at 12:38pm
Its possible the speed spools a turned to to low a flow to overcome the load
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 12:24am
Bruning were on the 7000 series.
They are 10 times better than the Pioneer that most or all brands use now...
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 11:47am
7000-series couplers were capable of coupling with balls or points. I don't remember the brand, but the two tip types was unique to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 12:12pm
Have a couple things here that have both balls and points on same unit. All work with 220 and 3  8000's
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 4:00pm
As Ron said, they were Bruning couplers on the 7000 series. Pretty trouble free in my estimation. They would accept the Bruning male ends or the pioneer ends.
