185 brakes
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Topic: 185 brakes
    Posted: 26 Jul 2025 at 1:36pm
Need to replace the brakes on the 185, what kind of lube can one use mainly on the band linkages and on the balls or should I just kleen and free all parts and don't bother with any lube? Thanks Dave
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 1:56pm
white lithium on the linkages if you got some; otherwise some heavy lube , Red & Tacky is a good one.
Nothing on the balls or tracks…lube of any kind will attract and keep dirt & grit which will eventually “ gum up the works “ which can lead to unexpected lock-up.
Note that it is important to have the gap set correctly between the brake disc(s) and the housing per the manual.
Edited by Gatz in NE - 26 Jul 2025 at 2:01pm
