D17 rear spinout rim |
Post Reply ![]() |
MichaelT ![]() Bronze Level ![]() ![]() Joined: 30 Oct 2023 Location: Missouri Points: 20 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Jul 2025 at 6:55pm |
Has anyone ever patched the rusted thru hole in my D17 spinout rim,
Is welding it a option or JB weld or has anyone got a suggestion |
Gary(VA) ![]() Silver Level ![]() Joined: 13 Sep 2009 Location: Troutville, VA Points: 341 |
Best way I’ve found is to get a donor rim and cut out a good section then cut out bad area in rim and weld in good piece.
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5232 |
Gary is correct but smaller rust thru holes can be patched with a small patch welded in after cutting the rusted area out. A good welder can make it nearly invisible to find. I had one repaired that was only 1”x1”.
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9893 |
Welding is a great option. Once the welding is complete, smooth with a flapper disk on an angle grinder. Any imperfections may be filled with an epoxy and made smooth. Most epoxies are easily smoothed with a wet finger. Best wait until the epoxy begins to get to a plastic consistency. Sand smooth once epoxy gets solid. A good rust resistant primer and paint to top off the repair. Make sure the paint is COMPLETELY dry, before mounting the tube and tire.
Post Reply ![]() |
