6080 brake fluid? |
skateboarder68
Joined: 29 Jan 2011 Location: Keota, IA Points: 377 |
Topic: 6080 brake fluid?Posted: 24 Jul 2025 at 6:41pm |
Book says 10w10. Found a quart of non detergent 10 weight oil at O’Reileys. Will this work? Thanks
Orange & Silver still earnin their keep on the farm: R62, Series IV D17 nf, 185, 6080, 6080 fwa, 220, 1968 D21, 7045, DT240.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2481 |
Posted: 24 Jul 2025 at 8:40pm |
Not saying that it won't work, but I would just use some regular hydraulic oil. Just don't use brake fluid.
DrAllis
Posted: 25 Jul 2025 at 8:20am |
We always used ATF/Dexron and kept a couple of 1 quart jogs on the shelf just for 6000 series brakes.
Hurst
Joined: 11 Sep 2009 Location: Midway, Ky Points: 1220 |
Posted: 25 Jul 2025 at 9:27am |
It's a mineral oil brake fluid. New Holland still sells it for around $20 a quart. NH part number is 73340450. LHM brake fluid is what it would be called in the automotive world. I think some European car manufacturers used it for a while, like Citroen. It's designed to use a mineral oil because if any bypasses the seals in the axles, it will mix with the hydraulic oil in the rear end without issue. If you are losing a good amount of fluid, you may be due to replace the piston seals in the trumpets.
Hurst |
1979 Allis Chalmers 7000
5800 Hours |
DonDittmar
Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2517 |
Posted: 25 Jul 2025 at 10:27am |
I think Massey used the same typ of mineral fluid in their tractors
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
Ky.Allis
Joined: 31 Jan 2010 Location: Kentucky Points: 1046 |
Posted: 25 Jul 2025 at 4:12pm |
Why did AC make this oddball? Fiat design?
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90628 |
Posted: 25 Jul 2025 at 4:24pm |
IM with the DR.. and OLDER type of trans fluid is 10w and would be good.. Not the NEW MERCON LV or Dextron 6.. ETC... Use the older stuff that is not synthetic and full of addatives, detergents.... Type A, F, Dextron 1-2, etc.
