Oil pressure
Stoges View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stoges Quote  Post ReplyReply Direct Link To This Post Topic: Oil pressure
    Posted: 17 Jul 2025 at 10:39am
What should the running oil pressure be on aD17?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2025 at 10:50am
For a full-flow lubrication system on a gas engine, the max you should ever see would be about 35 psi, as the regulator is set for 32 psi.  Why don't you tell us what you have at wide open throttle and at slow idle and what weight of oil and a "hot" reading would be best.
