7000 Oil Cooler Lines
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Topic: 7000 Oil Cooler Lines
    Posted: 16 Jul 2025 at 12:18am
My 7000 has started seeping oil at the oil cooler lines. I plan to replace the 70918980 unions, just curious if there is anything else that might surprise me when I take it apart, or if there are common failures on associated parts? Looks like it should be straightforward, but haven't done this particular application before. Thank you in advance.
Ted
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2025 at 7:29am
The unions are just a rubber crush donut. You might try just tightening them a little more.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2025 at 8:20am
hardest part is digging the old ones out of the fittings , some times you can hook them with a pick and screw the nut off of them
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2025 at 11:58am
If I'm replacing them, I use a small hand held torch to burn them out.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2025 at 10:52am
I tightened them Saturday, the leak got much worse while baling Sunday. When I took it apart the fitting unscrewed out of the block. After getting everything apart I found the issue - the fitting on the block had the wrong union. I'm surprised it held as long as it did.
This page was generated in 0.123 seconds.
