Any restorers in southern Mich for a WD
Docrock117 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Docrock117 Quote  Post ReplyReply Direct Link To This Post Topic: Any restorers in southern Mich for a WD
    Posted: 12 Jul 2025 at 1:41am
Looking for some help finding someone for a restoration of a WD, believe it’s a 1949 purchased by my Grandpa new then ( 1 owner ). Live in southern Michigan, south of Kzoo.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2025 at 9:39am
Serial number is on the back of the rear end casting, left side, Starts with "WD" then number. Look up on tractordata dot com for build sequence. That's the easiest source I found before when I was looking.
WD I have, bought three years ago, was built within two weeks of the one on the farm growing up.
Post some pictures of the tractor and condition you are starting with.
Edited by jvin248 - 12 Jul 2025 at 9:39am
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 12:21am
If you could get it over here I could probably do it… only a 8.5 hour road trip….
Would love to do another WD.
But that would be a long road trip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Docrock117 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 7:27pm
here are 2 images I just took. The first is a number I found between the transmission and the metal box to contain the battery. If this is the serial number it makes it a 1955 wd45, is that correct. The sticker/ label on the front only says WD. uploads/25750/image0.jpeg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Docrock117 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 7:28pm
here is a shot of the tractor itself.uploads/25750/image1.jpeg
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 7:34pm
That is a casting number. The serial number is stamped into a flat pad on the vertical surface of the rear housing above the lift arm crossbar. Sometimes you have to scrape a bit to make the number readable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 7:40pm
Late 1952 or 53 curved stick "WD" not a "WD-45".
Post Options Post Options   Thanks (0) Thanks(0)   Quote Docrock117 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 8:19pm
that’s what I always thought which is why that number confused me. I’ll go back out to the barn and see if I can find the number again
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 8:23pm
Just above the lift arm shaft on the LEFT side close to the square headed setscrew for the left brake.  WDxxxxxx.........should be 127000 or newer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Docrock117 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 9:45pm
I just don’t see anything there? uploads/25750/image0_2025-07-13_21-44-12.jpeg
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 10:12pm
Need an electric wire brush to get rid of all the rust and barnacles. It is stamped and has to be clean to see it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Docrock117 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 10:16pm
ok, will give that a shot in the morning. Thanks for all your help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 10:40pm
Doesn’t look to be in too bad of shape!!
Does it run?
Even looks like original paint and decals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Docrock117 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 10:51pm
bit of a long story but last time I started it it ran but could only get it into reverse. It had been kept in barn its whole life that my grandfather built for it. Then in 2016 we had a 22” wet snow event and the roof collapsed. There is a slight dent in the fuel tank from that but no other major visible damage. Problem then was, didn’t have anywhere to put it so it sat outside while I had barn demo’ed and new barn built but that took about 8 months. I traveled a lot for work so it has just sat there. Battery is cashed and the fuel leaks as soon as I open butterfly valve. Tires also need to be replaced. I have it up on blocks at the moment. Tires are at least 40 years old. So it has not run since 2017. I’m now retired and would like to give it life again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 6:30am
I'm not near my tractor but it looks like (in the book) the serial number is just ABOVE that square headed setscrew.
Edited by DrAllis - 14 Jul 2025 at 6:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Docrock117 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 4:28pm
ran the wire brush across it. I’m at the point I’m afraid to go much farther as I’m not sure if I will remove the pitting or the ser number first. I can see pretty clearly WD 13_739. I believe the other number is a 4. The area is pretty pitted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 7:25pm
13xxxx serial number puts it in the 1953 WD production series.
Some WD45 features were added ahead of time, like the "bent shifter" and other features short of the WD45 engine. But maybe you have that or it was upgraded. Photo of the other side of the engine could reveal. If it has a plate behind the mag or distributor or a solid casting with a boss.
So you could have a very interesting model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 8:33pm
Dust it with some chalk...
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 8:53pm
Welcome to the forum! Family tractors are great projects! They are worth spending the money on.
A&W Tractor can do any mechanical work or complete restorations. We just dropped 2 tractors off back in IN that we worked on, one was near La Porte.
Looks like you can take either ferry across to us or go through Chicago. We can also pickup/deliver.
www.awtractor.com
A&W TRACTOR 920-598-1287
