WD stuck in reverse
badjeep View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote badjeep Quote  Post ReplyReply Direct Link To This Post Topic: WD stuck in reverse
    Posted: 11 Jul 2025 at 6:05pm
Backed out of the shed the other day and tractor would not come out of  reverse, shifter will not move out of reverse. Thought I would ask for suggestions of what may be possibly wrong before I tore into it. Tractor is light duty only, pulls fuel trailer around yard and occasioal parade. Thanks for any help.
In the shed- 7020,7060, L2 X (2), CII, WD X (2), 200, 210, 611H, 440, Fiat Allis 345B
Leadoff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2025 at 8:36pm
Badjeep
There are several threads on this topic on this Forum.  Google Allis Chalmers wd/wd45 gear shifter stuck in reverse, or use the Forum search tool
Here is a link to one of the threads on this Forum - good directions
I have a D15 Series II with similar issues, and same sort of procedure to sort it out
My 0.02$ CDN worth, make darn sure you don't drop anything down the hole when you open up the top access to the transmission.  There are keys on the side of the hole the shifter sit in - handle very very very carefully!!!!!!
Good luck
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
This page was generated in 0.104 seconds.
