190XT traction booster |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5458 |
Topic: 190XT traction boosterPosted: 08 Jul 2025 at 7:21pm |
Need a little help, a picture of the linkages is what I am hoping for. My XT was missing the linkages when I bought it so I purchased the missing items and painted them along with my tractor 10 years ago. I finally got around to installing them this week and ran into an issue when I try to install the position control rod going to the lift arm. When I try to install it in the lift arm, it seams that maybe I have something wrong at the feed back lever/bell crank. Maybe in the wrong hole or I have it orientated wrong. Also, the position control rod and the control rod are different lengths so I have no idea which is which? Hoping someone will take some measurements of those 2 rods and a picture of the bell crank-feed back lever connections for me. My factory manual doesn’t give me those measurements. Thanks in advance
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2481 |
Posted: 08 Jul 2025 at 9:21pm |
In the top picture, the flat piece that the two rods are attached to, needs to be flipped forward instead of backwards. I don't know if the rods are in the correct holes or not.
DrAllis
Posted: 08 Jul 2025 at 9:30pm |
Once you flip that piece of linkage over, I was always taught to install a 3/8" bolt and nut in the unused top hole to stop it from ever flipping over again.
AC720Man
Posted: 09 Jul 2025 at 3:19pm |
Thanks, do the rods go in the same holes after I flip it over?
DrAllis
Posted: 09 Jul 2025 at 6:42pm |
I think your owners manual has a picture of that and what the extra holes are for.
AC720Man
Posted: 10 Jul 2025 at 8:19pm |
![]() Found this sketch near the end of my service manual. Does this look correct? |
DrAllis
Posted: 10 Jul 2025 at 9:33pm |
That's it.
AC720Man
Posted: 11 Jul 2025 at 10:55am |
Thank you sir.
