CA Rad Shutters
1955CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Topic: CA Rad Shutters
    Posted: 03 Jul 2025 at 5:58am
Anyone have some pics of the rad shutters and how they are installed in the CA? I have an original set on the way, my 55 has the holes in the grill shell for the crank and 4 holes in the front, but I've never actually seen them on a tractor.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2025 at 6:47am
The crank goes through the hole, that will get you 'clocked'. Guessing the mounting holes should line up then fairly easily.
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2025 at 9:07am
Not sure it's clear enough (this was one of those Turkey made radiator replacements that wasn't quite right for a CA, but close enough):
Edited by dfwallis - 03 Jul 2025 at 9:08am
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2025 at 9:31am
So it mounts to the grill radiator? I wasn't sure if it went on the rad or the grill shell.
Edited by 1955CA - 03 Jul 2025 at 9:33am
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2025 at 10:30am
It mounts to the radiator itself.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2025 at 5:16pm
Thank you very much gentlemen.
