WD45 coil wires
Driverdan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Driverdan Quote  Post ReplyReply Direct Link To This Post Topic: WD45 coil wires
    Posted: 01 Jul 2025 at 3:45pm
...I have two WD45's...on one the wire from ignition is connected into + terminal on the coil. On the other, the wire from the ignition is connected to the - terminal on the coil... Can someone please tell me which is correct? (Both tractors are 6 volt positive ground,) Thanks...Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2025 at 3:58pm
If both are truly POSITIVE  ground, the wire from the distributer back to the coil should be the same or on the + post of the coil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Driverdan Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2025 at 5:02pm
Dr Allis...thank you do much! Thus is not the first time you have helped me out, and your knowledge is always appreciated!!
