N5 separator clutch issue
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Topic: N5 separator clutch issue
    Posted: 30 Jun 2025 at 6:36pm
Getting ready to run some wheat with my N5 and I noticed while hooking up the header that the straw spreader and the sieve was rotating very slowly without the separator engaged, then I heard kind of a bang noise, separator will turn on with the switch fine, but did the same thing when I turned it on and off. Any ideas? Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2025 at 8:21pm
Sooooo, you've been faithfully greasing the separator clutch bearing once a week right ???  Or do you even know what I'm talking about ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2025 at 8:45pm
Yes I certainly do know where it’s at, weekly? No I don’t run that many acres and don’t put that many hours on it. But it does indeed get greased, hell it only takes me a day to run the wheat I have. That’s why I run a junky old N5 to start with. So you thinking the bearing is failing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2025 at 8:55pm
Gotta ask !!! Many second and third owners have not a clue about that bearing. If the separator is creeping on its own, the only way is something wrong in that clutch area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2025 at 9:11pm
Gotcha, yeah have to tare in to it I guess, hopefully it can be fixed without spending what the whole machine is worth!
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2025 at 8:28am
Try unhooking the hydraulic hose running to the rotary coupler on the separator clutch shaft. Start it up. Do not engage the separator clutch, see if separator turns then, or if oil spurts out of the hose
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2025 at 8:30am
Clutch pins also could be so badly worn that they are causing a bind that won't let the clutch fully separate when disengaged
Darrel
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2025 at 8:31am
Ah the old split main clutch shaft issues. You have had excellent advice here - just an explanation. The reason to disconnect the supply hose is to eliminate the 2% possibility there is something wrong in the valve stack. IF no oil squirts out of the hose (thus meaning the clutch is doing what it is supposed to be doing) then you might as well get a book, follow step by step and repair the mechanical issues which could the aforementioned  pilot bearing, the floater pins, warped clutch or separator plates. The company even provided a ledge to lay the LH assembly on while you are in there fixing everything. :-)  Thank goodness for the evolution to the one piece main clutch shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2025 at 5:13pm
Thanks for all the replies, the next day I went and tried it again and it worked fine, only thing I did add a gallon of ATF and gave the clutch a good greasing again and it never did it again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2025 at 5:57pm
Double post
Edited by AC 426 power - 07 Jul 2025 at 5:58pm
