f/s refreshed gleaner E g226 engine
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Topic: f/s refreshed gleaner E g226 engine
    Posted: 27 Jun 2025 at 12:32pm
interesting store , went to run engine (block said M code) and a mouse had filled up the head and manifold ,
cleaned out and started , did not run right , compression tested and one hole was low , so pulled apart ,had been overhaul at one time and had Z code pistons in it , like new , to good to salvage so it got new rings and gasket and a valve job now it runs great , can here run 30 psi oil pressure and changed over to tractor governor thanks 5o7 7six6 0551
Edited by steve fischer - 27 Jun 2025 at 2:13pm
