WD45 Front Crank Seal Speedi Sleeve
Lingle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lingle Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Front Crank Seal Speedi Sleeve
    Posted: 23 Jun 2025 at 9:30am
during my rebuild, I must have overlooked the front crankshaft seal surface is deeply grooved.  I am looking for a speedi sleeve for it, still need to measure it to be sure, but thought I would post here if anyone knows a part number off hand.  I believe the front seal is a rope type, like the 2 piece rear main, but havent confirmed what is in my Reliance gasket kit, maybe its a rubber seal, regardless the seal surface will not seal given the deep groove in it.  thanks everyone!
35 and 41 WM crawlers, 49 WD, 53 WD45 wide front, 49 JD A, 52 JD B
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2025 at 6:36am
Don't remember the part no. but the speedy sleeve is a good idea. Just a regular oil seal in the timing cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2025 at 7:51am
I think OEM was lip seal with a felt ring out front
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lingle Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2025 at 8:11am
correct, the front seal is a lip seal with a felt ring further forward so it extends quite a bit from the cover.  I found SKF 99150 but its install depth is not deep enough with the provided install sleeve(only up to about an inch, based on measuring I need to move it about 2.75" onto the shaft), but I think I could move it further down the shaft to get it into position.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2025 at 8:34am
You can use a piece of exhaust tubing or pipe to install a Speedi-sleeve deeper on a shaft, just takes a bit of searching at times to find something with the right ID to use in place of the supplied driver.
