Allis 720 Transaxle part needed
Phammy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phammy Quote  Post ReplyReply Direct Link To This Post Topic: Allis 720 Transaxle part needed
    Posted: 23 Jun 2025 at 6:42am
I am looking for part number 178667 (SHAFT, drive) in the transmission group. If anyone is parting out their 720 I would be willing to purchase the entire transaxle. Broken or stripped internal parts are okay just so long as the drive shaft is in good shape. Thank you and God bless.
Phil Hammitt
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2025 at 3:54pm
I don't believe that is an Allis number.  Is that a Simplicity number?  They are not the same number for the same part.
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phammy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2025 at 12:29pm
Simplicity, transmission group, pg.46 diagram, and 47 for the part number #21, 178667.
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2025 at 3:34pm
I do not have a Simplicity parts book.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phammy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2025 at 10:25pm
Would you like one? I haven't been on here very long and not sure how to send a copy? The Simplicity parts list and numbers are identical. Maybe you know a way? Thank you and God bless.
Phil Hammitt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2025 at 12:35am
Do you know what the allis part number is
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phammy Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2025 at 6:03am
Please read the original posting.
AcFordHawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2025 at 9:50am
Screen shot from the Simplicity PDF manual I have to aid in visualizing which shaft.  Don't think I have an Allis manual but will check later today.
IB (restoring), MF GC1705, MF 2705E
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phammy Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2025 at 11:03pm
This is the same diagram I have. The following page identifies the parts. The part I'm looking for which is #21. It's called a drive shaft. It's for the rear PTO. It's on the rear of the transaxle which drives the implements that mount to the 3 point hitch. If you would have read my original post you would have known exactly what I'm looking for.
Please people no more stupid questions! Thank you and God bless
Phil Hammitt
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2025 at 4:53am
Good luck in your quest. Your origial post was vague but anything asked for clarification from you is obviously a "stupid question".
Again, Good Luck
That's All Folks!
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2025 at 12:10am
Phil, a little rude aren't you? You ask for help and then stomp on peoples toes when they're trying to help you out. Then tell em' "God Bless".  Yeah, I'm wit' Codger. Good Luck!! And God Bless!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2025 at 8:50am
Thanks Steve.  I had been willing to try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2025 at 10:50am
IP: says  ATT -  Not MN
Illinois
City:Chicago
SpamHaus - PBL (Spamhaus Maintained)ListedListed; Listed by PBL, see https://check.spamhaus.org/query/ip/107.77.206.184
