Any Tips of Removing White Steering Wheel?
Oldwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldwrench Quote  Post ReplyReply Direct Link To This Post Topic: Any Tips of Removing White Steering Wheel?
    Posted: 22 Jun 2025 at 8:43am
So I treated the D17IV to a new cream colored steering wheel, along with a few new gauges and general sprucing up.  The old one has been on since new, and the nut and shaft area under the "AC" cover is pretty rusty.  I'm soaking it in penetrating oil.  I don't see any straightforward way to use any type of standard steering wheel puller.  The three spokes and tapered profile underneath the wheel don't let me use any type of flat stock to use with a puller.
I'll figure something out eventually,  even if its a 5 lb hammer while pushing it up with my knees (I don't care about the old wheel, which is shot).  But I'm wondering if there is some clever way to fashion a strap or something to pull the wheel off easily.  I'm sure everyone in the group has removed one of these at some point. The new one is going on with NeverSeize for sure.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2025 at 8:59am
Can't be saved when removing it.  Break off the bakelite coating around the center of the wheel, cut off the outer ring.  If the nut doesn't loosen, use a dremel tool and cut it off.  I have used a bearing puller to get the steering wheel off after that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2025 at 9:08am
heating with a propane torch can help also..
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2025 at 9:25am
Take an air chisel with a rounded end bit.Let the bit hit on the center of the shaft while holding up on the steering wheel.Almost always come loose that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2025 at 11:45am
I have replaced the jaws on a 3 jaw puller with thin bendable metal straps to go down and around the steering wheel spokes. First soaking the splines and much patience I've removed many 3 spoke D series plastic steering wheels without damage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2025 at 11:58am
You're throwing the old steer wheel away !!  Bust off the plastic in the center. Put a good three-jaw puller on the hub and get it under pressure. Bang on the hub or the puller screw end or use quick torch heat to make her pop loose.  Remove the probably worn out snap ring on the steering shaft. Stack machine washers in there instead to get the up/down distance correct and install the new steering wheel. Work some oil down and into the bronze bushings before final wheel install.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldwrench Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2025 at 12:47pm
Thanks to all for the replies.  They all make sense, and I see how to tackle it now.  I hadn't thought about anything beyond the wheel itself, but Dr.'s suggestion to use the chance to correct for play in the shaft with a few washers (I might try to find bronze or something that won't rust) and oiling the bushing are well taken.
I probably won't get to the job until this week, but will let everyone know how it goes.  Thanks!
