New to AC with a WC, rocker shaft / oil pressure
Blown331 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blown331 Quote  Post ReplyReply Direct Link To This Post Topic: New to AC with a WC, rocker shaft / oil pressure
    Posted: 21 Jun 2025 at 5:38pm
I bought my first ever Allis Chalmers which is a 1936 WC. It appears to have a 1947 electric start engine in it. I got a great deal on it and it's in nice condition and runs great.
When it gets warm the oil pressure gets a little lower than I would like. I'm running a Fram filter with straight 30 weight oil. I tried switching back to the Carquest filter that was on it with no change. The filter standpipe is in place. I added one washer under the oil pressure relief valve cap and did pick up some pressure. I think a switch to 20w50 oil may be what I need. But I also recently learned that the rocker arm shaft is somewhat pressurized and sealed on the ends with cork. I'm guessing I may need those corks replaced. Would this be responsible for the lower oil pressure? I have a parts book and have the part number for the corks but nothing really comes up online. Are people just making these? It seems like driving in a freeze plug would be a better idea. Anyone do this? What size? Any other comments or suggestions are welcome. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2025 at 6:07pm
what is the pressure ?  These engines dont need or have a LOT of pressure..
evan austin View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote evan austin Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2025 at 6:51pm
When I had my WD45 engine apart last year, I think I used tapered rubber plugs in the ends of the rocker shaft instead of corks. I think I had to trim some off of the smaller end because they were long, but I oiled them up and they pressed right in. Still use the cotter pin behind them to keep them from blowing out. Not sure what the real manual calls for, but the I&T manual says that normal oil pressure is 11psi. Or, like my operators manual says, somewhere between the "O" and the "M" of "NORMAL" on the gauge
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2025 at 5:52am
Whats the oil pressure? They are a bypass system and only ran 15 psi at best when new.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blown331 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2025 at 9:09am
Oil pressure is on the M when cold. Adding the washer took me up to the A. But when warm it drops to the line at the bottom of the normal range. Slightly below at idle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2025 at 9:23am
normal pump wear on an 90 year old engine can cause loss of pressure at low idle.. Remember its a BYPASS SYSTEM.. The PRESSURE is not what is going to the bearings, it is just BACKPRESSURE on the system caused by the filter.... You might still have plenty of oil going to the bearings/ cam / rods in FLOW... just not much pressure.. I have seen these engines run with less than 5 psi at idle.. Pickup to 12- 15 psi at 1600 RPM is good... You idea of trying a 20w 50 oil would be a good test..
if your going to take the valve cover off... run the engine at idle and SEE what you have for oil flow at the top end..
Edited by steve(ill) - 23 Jun 2025 at 9:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2025 at 4:05pm
Sounds like it's doing fine.  What it probably needs is an overhaul.  Cam bearings are a major issue on these engines.  The camshaft is actually the main oil galley and worn bushings cause low pressure issues.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blown331 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2025 at 4:35pm
It starts and runs really good with plenty of compression and no smoke. I would say pistons and cylinders seem to be in good shape. Perhaps that part of the engine was overhauled but the cam bearings were not addressed.
I plan on pulling the valve cover, adjusting the valves and replacing the corks in the rocker arms. I feel like if the rocker arm shaft is carrying pressurized oil but it's just pouring out of the end, that would decrease oil pressure throughout the entire oiling system. I guess I'll switch to 20w50 as well. I feel like that has to make a difference.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2025 at 4:55pm
If you're corks are bad you'll know it. When running, you'll be able to either see oil running our the end of the shafts past the corks or no oil will come out there becasue the corks are doing their job.
Do you mean when it's hot it runs at or below the "N" on the gauge?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blown331 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2025 at 8:22pm
Yes it's below the N on the gauge when hot. It's at the L when cold.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2025 at 12:14am
My 49 WD would take like 3-4 minutes before it would get oil pressure, come to find out the pump screen was plugged with sludge. So I’m in the process of cleaning all sludge out and replacing the crank seals and all the gaskets on the engine.
So take that into consideration of possible problems….
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2025 at 6:56am
Adding a quart of Lucas oil conditioner would probably help some.
