power steering failure
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Topic: power steering failure
    Posted: 17 Jun 2025 at 6:18pm
AC-D15 II power steering suddenly failed to function. has always been greased properly. has been occasionly low on hydrlicaulic steering oil.   diagnosis??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2025 at 7:35pm
Remove the grille screen. Remove the power steering breather and check the oil level. If you can see the oil just above the steering gear inside that is full enough. Start the engine and throttle it up about half-way. If the pump is working at all, the oil will be moving around when you look into the hole with a flashlite. No oil movement whatsoever means a failed power steering pump I would say.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2025 at 5:26pm
I see you were using your D-15 II today??    Power steering fixed ??
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2025 at 5:49pm
Yes, I have it relatively fixed.  My boys reminded me I was getting older and was loosing arm strength.  They reprimanded me that I should not compare it to John Deere's hydrostatic. steering. It does steer with less effort than  the D-12 III which  js not equipped with power steering, The D-17 IV Steers the easiest. We continue to farm with all three of them,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2025 at 7:10pm
There are a couple of places you can oil that may help. #1. Where the steering shaft goes thru a support block underneath the carburetor, oil the shaft and work it back and forth. Up ahead on the same shaft is a splined coupling. Spray some WD40 in that splined coupling socket. I would tell you to oil underneath the steering wheel because that area can be dry too, but very difficult to get at to oil it.
