Wd oil pan removal
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Topic: Wd oil pan removal
    Posted: 13 Jun 2025 at 11:39pm
Good evening a’ll
Decide to pull the engine pan to see what was in there due to finding dirt/ sludge on the dipstick.
Found the oil pump screen almost plugged and lots of sludge in the bottom of the pan.
Should I check/ do anymore than clean it up and reassemble?
Ran just fine (as of the last it got ran a couple weeks ago) but thought I might try to prevent problems from happening. I’m putting new crank seals in and wouldn’t mind some advice on the rear one….
1955 AC WD45 diesel with D262 repower, 1949 AC WD, 1963 A-C D17 series 3
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2025 at 5:31am
Flywheel has to come off to do the rear main.  Watch this video and do EXACTLY as he says to get the pan seals done right.
AaronSEIA
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2025 at 6:38am
The guy that used to work on our tractors years ago removed the oil pan on a WD NF for us  and put it back on while it was on the tractor.
kevin LA-CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin LA-CA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2025 at 8:37am
It can be done on the tractor. It will be frustrating.
One key iin addition to the other hints- remove front engine support. It pan looks like it should fit, but just keeps knocking off the front gasket. Use the short set of end gaskets for WD motor. Two sets are supplied in each pan gasket kit.
Can anyone confirm that front seal can be replaced without removing front timing cover?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2025 at 9:08am
I will be removing the engine to get to the clutch do to the possibility it is oil soaked…
Never pulled a flywheel off a 4 cylinder..
Thanks!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2025 at 1:05pm
Have your belt cinched up tight. They are heavy. Bolt hole are not even spaced will only fit one way.
