Wheel Pusher Bolts
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Topic: Wheel Pusher Bolts
    Posted: 13 Jun 2025 at 2:22pm
Has anyone made their own pusher bolts for changing wheel width? I need to widen my 190xt some but am really not interested in paying $150-$200 for 3 bolts. Looks like I could make my own for a lot cheaper.
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 4:46pm
Maybe you are that talented. They must be at least a grade 8 bolt and they must be machined correctly to work.
Edited by DrAllis - 13 Jun 2025 at 4:46pm
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 4:54pm
If I sent them to you, can I trust you to send them back when you’re done?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 5:25pm
If one would machine down the end of a grade 8 bolt to the pusher bolts profile, what's left can't still be grade 8 can it ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 5:36pm
That’s what I was thinking. I just need to know the length and diameter of the bolt and diameter of the milled down shank
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 5:38pm
Thanks for the offer but I would be afraid I’d break one! I wouldn’t feel so bad if I break one that’s mine.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 6:58pm
I found that to be an interesting question! Since I know a little metallurgy, but in a completely different arena, I looked a little bit. It looks to me like Grade 8 bolts are through hardened, whereas Grade 5’s not quite. So in that sense it seems like they would still be Grade 8.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 8:55pm
Have you tried A&W Tractor near Shawano, WI? Only 1 hr away from you! https://awtractor.com/product/wheel-jack-bolt-235674/
www.awtractor.com
A&W TRACTOR 920-598-1287
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 9:44pm
Better check the thread pitch. I dont know about the 190 bolts but im pretty sure the are not standard pitch on the 7000/8000 bolts
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 9:52pm
Thread pitch are normal 3/4" NC on those smaller bolts.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2025 at 6:35am
If you had a good machine shop cut down the ends of the bolts and explain exactly what you need it shouldn't change the grade if they went slow and didn't get the bolts too hot.
Going back about 40 years but think we used a grinder to cut the ends down to get the hubs loose on our D19.
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2025 at 7:10am
I made a set for my D-19 and they worked just fine! Grade 8, coarse three. Good luck!
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2025 at 11:20am
  Do you need dimensions? If you do I will try to find mine and take some measurements.
Edited by lentsch - 15 Jun 2025 at 11:23am
WD,D15,190XT,7000,8010x2,7060,8070
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2025 at 3:59pm
I looked at mine today, grade 8, but the threads start at the base of the hex head.
a bolt that long would not usually have threads the full length of the bolt. Just something to consider if you make a set. I thought I had an extra set to sell but I don't. I have a spare set of 70xx, 80xx I would part with
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2025 at 5:40pm
Ive got 3 lathes and I bought mine from agco. Firstly I know they will work. Secondly by the time I find fully threaded grade 8 bolts long enough,spend the time to turn them I can have 3 or 4 sets of wheels moved and if I count my time on the lathe i wont save any money
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2025 at 6:24pm
Not to mention breaking up a bunch of carbide trying to turn material that hard
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2025 at 7:16pm
I wouldn't know where to look to find a full thread Gr8 3/4" NC bolt 6 inches long anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2025 at 8:05pm
Try the Bolt Depot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2025 at 9:28pm
McMaster Carr has grade 8  all thread rod in many lengths.Its what I used to solve the problem of the 3pt bracket on my D15 getting loose in the housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2025 at 9:45pm
Some dimensions would be great!
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2025 at 5:22am
ZORO.com (a Grainger subsidiary) and Grainger both have Grade 8 bolts that are threaded all the way.
Edited by WF owner - 16 Jun 2025 at 5:29am
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2025 at 8:29am
If you search on eBay for "Allis Wheel Pusher Bolts" you will find a couple of people who make them for quite a bit less than AGCO.  Might be another avenue to explore.
Best,
Hurst
1979 Allis Chalmers 7000
5800 Hours
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2025 at 10:38am
From what I remember they are threaded by the head with a protrusion to push against the wheel. To make a replacement I would find a piece of shaft material the correct diameter and cut it to length and just use a grade eight bolt to push it. The only reason it has to be one piece is to make it easier to remove, and a good magnet should do the job. If not, you have your wheel loose, just move it away a little and push the shaft pieces back out.
Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2025 at 2:16pm
I tried something similar to this on my 7000, and the biggest call out is it can mushroom the end of the bolts so it is very difficult to back out through the threads again.  The factor bolt puts all that pressure on and undercut part of the pusher bolt, so even if it mushrooms out slightly, it will still pass through the threads in the wedge when you remove it.
Hurst
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2025 at 3:53pm
Im now going to say what i tried to gently say in my earlier posts. I understand agco bolts seem expensive. I understand farmer ingenuity to save money. Totally. Ive been very blessed so their cost is not aproblem for me. Believe me it has not always been that way. In the case of removing wheel wedges the forces can be tremendous. Mess around and ruin a wedge or 4 and the costs get way out of hand. I said all that to say this. I think the cheapest route is agco bolts,move the wheels and be done with it. Given as friendly advice from experience
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2025 at 5:26pm
Again, I have 3 that you can borrow. I’m gonna take them down to our local Machine shop and have the threads straightened. The 1st inch of the threads doesn’t look the best.
