172 Rotary Cutter
D17 Okie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 Okie Quote  Post ReplyReply Direct Link To This Post Topic: 172 Rotary Cutter
    Posted: 10 Jun 2025 at 10:24am
How does a person remove the shaft from a 172 Rotary Cutter for the purpose of replacing the bearing at the bottom of the shaft?  I am assuming to open the back plate of the gear box, but I am not sure what I will find when I do.  Is the bearing easy to come by?
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2025 at 11:01am
you have to take the gearbox apart, theres a gear on the end of that shaft you need to pull off, so the shaft can drop out. There is a bearing behind the gear, and there is supposed to be a seal on the bottom of that housing, in your picture
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 Okie Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 9:46am
Is it possible to get a rebuild kit with seals and bearings for this, or am I wiser to look for a new mower?
Allis dave View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 10:03am
I just rebuilt the gearbox on my 160 mower last year. We are lucky to have an old time type local farm store. I took in all my old bearings and seals and left with brand new ones.
You won't find a "kit" but everything should be available.
I don't rememebr exactly now but you can tighten up the bottom bearing by making a thinner shim out of some gasket material. I didn't realize this until I was putitng mine back together. I wouldn't have needed to buy new bearing.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 2:56pm
Allis Chalmers used standard sizes, so everything is available through a bearing house, except the gaskets, which you have to make. The shaft you're dealing with you have to set the load with a locknut that's holding the gear on, the cross shaft has shims
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 Okie Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 3:56pm
What should the lock nut be tightened to in order to set the load?  It seems like it may be difficult to remove based on the space available.  Do you happen to know the size of the lock nut?  1 1/2?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 4:07pm
I can measure it, the way I do it is to tighten it down until you feel a slight drag, and then leave it, too tight is worse than slightly lose.
 1 5/16 the nut  NF 2" socket, you have to heat the gear to get it off
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 4:08pm
Space available? You have to remove the top of the gearbox to get the nut off
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 Okie Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2025 at 9:21pm
Sorry, I have not done this before and trying to learn as I go. The nut came off but the gear is not cooperating. I broke 3 Chinese gear pullers after heating the gear up. I guess I need a serious puller after heating the gear up?
Edited by D17 Okie - 14 Jun 2025 at 9:21pm
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2025 at 7:03am
If you have a good machine shop around it'll probably pay you to have them pull the gear and do the work required
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2025 at 12:36pm
you have to have a big torch, not just a propane handheld, you have to start heating it evenly than take, preferably a brass drift and hammer the shaft out, gear pullers have a hard time grabbing the gear its rounded on the back side. The more solid the gearbox is, the easier it will hammer off, so if you have a way, block up the mower close to the gearbox so its good and solid, the better off you will be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 Okie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2025 at 12:54pm
Perfect. Thanks!
