Ac 170-175 front support?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Ac 170-175 front support?
    Posted: 29 May 2025 at 9:39pm
What was the reason some front supports were threaded for weights and others were not. These are both later models. One is tapped and other is not, both have wishbone fronts with hyd pump up front. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 11:09pm
 You mean the two front face holes like for the slab type weights ?? If you compare chassis serial numbers, I'm guessing the older one may have the threaded holes and the newer one doesn't. A cost reduction measure and everyone was using suitcase style weights by then anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2025 at 9:46pm
DrAllis, thanks for info. Makes perfect sense.Tracy
This page was generated in 0.115 seconds.
