Champ Job Maker heater runs and dies
Heliarc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heliarc Quote  Post ReplyReply Direct Link To This Post Topic: Champ Job Maker heater runs and dies
    Posted: 29 May 2025 at 12:16pm
Bought a Champ Job Maker heater for a song. Got it home. It runs briefly and dies. Fuel level is fine and fuel seems OK. I blew out all the lines excepting those in the gun, same thing. Runs and dies. Shut it off for about 1 second, it'll fire briefly and die again. Pump continues to run but no flame. I shut it off, cracked the gun line loose, turned it on. I get brief fuel flow from the gun line and it peters out. I open the bleeder while it's still running, good flow. I can stick my finger over the open bleeder and stop the flow, not sure if this is normal. Pump is definitely pulling fuel but after a few seconds it stops pushing anything to the gun line. Had the pump apart a few times, blew out everything I could find, no luck. Same thing. Runs and dies. Opened the transformer just a little when it's running but not flaming, good spark there. No unburnt fuel blowing out of the heater. Has a Webster 1725RPM pump.
I figure I need to get a gauge to it but I don't have on unless you can use an air pressure gauge.
Unknown on the history of this heater. I have not adjusted anything nor will I attempt to without the gauge and a decent understanding of what I'm doing.
Anyone run into something similar?
Edited by Heliarc - 29 May 2025 at 12:19pm
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 1:15pm
‘fuel seems OK’?
Maybe wrong fuel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heliarc Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 5:34pm
It's either heating oil or AG diesel. Either one should be fine for this unit.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 5:57pm
I have an old "Master" heater and does the same thing with a "Webster" pump. I borrowed a low pressure gauge and the pump on mine is shot. It will pull fuel for just a short bit but will not consistently. Pressure falls off and flame extinguishes although the burner nozzle "spits" unburned fuel as the electrodes are too distant.
Your pump is worn out. It will pull fuel for the short bit till fluid friction of filling the discharge line and pressurizing it. Once the pump begins to cavitate, the heater shuts down. Unable to further supply pressure or flow, the flame extinguishes until the heater is allowed to dwell and pressure bleeds down on the discharge side of the pump.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 6:35pm
are you sure the FUEL LINE and NOZZLE out of the pump are  clear and not plugged with GUM ?
Riprock View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riprock Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 11:42pm
I don't know that brand but i've seen several that have a pencil size nylon type filter inside the brass fuel line coming up out of the tank. You have to break the line and pull the tube out of the tank.
 Ive also seen one with a plastic fuel filter with an arrow that was installed backwards and would do the same thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2025 at 2:45am
That nylon filter in the pickup tube is a "Desa International" brand and it's associated holdings/brands out there. Cheap and effective but any loss, or reduction of differential pressure across the pickup tube will stall and flame out the heater. There will be an adjustment and a gauze, or foam filter, (washable) in the rear of the pump.
Basically a venturi effect pulls fuel from the tank to the burner ejecting it through a conical nozzle where the large fan atomizes the fuel and the mist makes contact with the burner electrodes. If the air fuel balance is disturbed, the heater flames out. Almost, but not quite the same principle an axial flow jet engine operates with.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2025 at 2:58am
Should also be a Flame Sensor on these, most can start as the electronics will set the flame but the sensor not see the Heat for the electronics will shut the pump down.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2025 at 2:07am
Sounds to me like the pickup tube/filter is plugged up...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heliarc Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2025 at 5:53am
Did you replace the pump and get it running afterwards? The pump is pricey. The heater is well worth it but I want to be sure.
Think an air gauge would do at least once?
That cavitation you mentioned. Looking back, the pump makes a noise that puts me in mind of that when it does out.
I was wondering if I could mix in 10%-20% hydro oil with the fuel and have it run. I have a LOT of hydro oil.
I still don't get how I can have good flow out the bleeder the entire time.
Edited by Heliarc - 01 Jun 2025 at 5:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2025 at 6:24am
Have you taken the nozzle itself apart? If it is a "Delavan", (sp) nozzle these have an internal screen. I assume you know this but many times on the "Webster" pumps there is an inlet screen inside the suction port and this is quite tiny. The discharge of the fuel oil should be angular and if pressure is not developed by the pump, (usually only about 30psi) the flame pattern cannot be developed.
Yes the pump is expensive. You can replace it with a "Suntec" variant but would need to match pressure and flow requirements which can be done if you know the original values.
If your pump is proven weak, you can thicken the fuel oil with hydraulic fluid and it will possibly work; how well is anyone's guess. The heater if it does work will require periodic cleaning as you are now buring waste oil which does not burn near as clean as fuel oil, or diesel fuel.
Free flow through the bleeder indicates fuel is being pulled from the tank. The bleeder however is offering no restriction to the flow internal to the pump. A clogged, or partially clogged discharge nozzle will offer the symptoms you are experiencing.
Edited by Codger - 01 Jun 2025 at 6:30am
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heliarc Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2025 at 7:31pm
Gotcha. I really know nothing about even furnace pumps in general besides they pump fuel oil. I have not taken the nozzle apart. I saw no need as the fuel from the gun line keeps dying out, figured no need to go further but if you figure I ought to I'll give it a shot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2025 at 8:09pm
Remove the discharge line feeding the nozzle from the pump. Check for fuel flow discharge and if present, block the port with a finger and see if pressure built is enough to push your finger away.
If you are making pressure, and the line is restricted, temporarily replace the line with a section of automotive rubber hose rated for fuel injection service and brass barbed fittings from a hardware store.
Those burners are better than anything you can get these days for sure. A photo would help to guide you.
What is the BTU rating of the heater?
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heliarc Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2025 at 9:10am
I do have fuel flowing out the end of the nozzle feed line. I've been calling that the gun line. I don't think I've tried blocking that off with my finger. I tried that on the bleeder and I can stop the flow pretty easily but I guess that doesn't mean anything. That will be a quick test though and I'll let you know how it goes. I'd think I should not be able to block the flow from the discharge end of the pump with a finger correct?
Not sure of the BTU on this furnace but I know it's a monster. I'll jot it down when I go out today.
I'm going to smell like a Lot Lizard that got confused about what sort of nozzle she wants...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2025 at 9:13am
No, you should not be able to stop the flow if the pump is making much pressure at all.
My wife calls diesel fuel "Man's Perfume". She swears I soak in it to promote soft skin.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heliarc Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2025 at 10:36am
My Father was always out under the hood of a VW diesel. I swear he loved to bathe in it! He loved wrenching on the VW IDI diesels.
I removed the discharge/nozzle/gun line from the discharge of the pump. I put my thumb over the hole and it's tough but I can stop it completely. I let a little pressure bleed out and in 2-3 seconds there was no more flow. I've had the pump stripped down to pretty well nothing and hit everything with compressed air before this. It acted exactly the same prior to and after stripping and blowing it out. I also removed the discharge fitting from the pump, removed the bleeder and blew down into the bleeder port. A little cylinder, looks like the inside of a spool valve shot out. There was a spring behind that. Fortunately I found everything, re-assembled, but same thing.
I'd like to put a gauge to this thing but I don't have a real furnace gauge. Think an air gauge would do for a few times? I use an air gauge for the oil pressure on a flathead Ford V-8. I'm starting to feel like the pump is kaput but I also wonder if someone before me might have been messing with that adjuster on the pump. I don't know how these things work though. Id think if someone somehow set it to just 20PSI messing with that, it still ought to hold 20PSI. After a few seconds I might get a few drips. Pressure starts out alright but drops to nothing. Sticking a finger over the hole might be a quick and dirty thing but I didn't think to do that and now I guess I know a little something more.
120,000 BTU by the way. This thing is going to be crazy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2025 at 11:03am
The spring and plunger is the pressure relief setup. Crank this all the way down and try to block the flow again. From the sounds of it, I think the pump is shot from this vantage point but if the pump doesn't move fuel with the relief cranked in, crank it all the way loose and re evaluate. It it moves fuel with no relief valve acting against fluid flow, the pump is shot and cavitating internally with little offered restriction. Pumps installed into any system will always have fluid restriction which is referred to as "back, or static pressure". Inherent to design. A pressure relief valve in one of these pumps has to overcome this static back pressure before it can output fuel flow.
I know the IDI VW diesels quite well from many years back. Worked on several, in different chassis. Easy to really "Wake Up", but high in cost to make them run well. Costs to keep them going got a bit pricey as they aged, but not a bad engine unless overheated.
120K BTU is a small heating appliance. Usually will consume just over a gallon an hour when running.
A Bourdon tube gauge would work but I would use a glycerin filled gauge so the pressure reading is steady. A non filled gauge will bounce all over the place.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heliarc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2025 at 7:01am
I'm feeling the pump as well. I don't understand why it would have decent pressure and then drop out but I don't think a good pump ought to do that. So I'm cranking that adjuster one way, test with thumb over the hole, move it the other way, test again. Cavitating. Now that you mention cavitating, right before the heater dies I can hear a sort of grindy noise but I think it's the pump cavitating.
Parts are getting pretty tough for the IDI anymore. Any precision parts such as injector nozzles don't pay enough so they'll be coming from India. If you need four, better order twelve. The guys who knew the injection pumps are either retired or dead. Bulletproof engines. I drove a lot of them. Not a darn thing for acceleration but they'd get you there come hell or high water, just in their own time. I overheated one to the point it seized up. Came back the next day ready to tow it home and the thing fired up like nothing was wrong. I inadvertently starved it for oil once. It was knocking like hell after that but it still ran alright for a few months until a Friend ran it out of oil again. Simple engines and with a tiny bit of maintenance it was nothing for them to go 260K and well over. Just the injection pumps scare me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2025 at 9:32am
Hydraulic pumps can and do scream when they cavitate. Dependent upon oil viscosity it can become audible to the human ear. Not so much with fuel oil but still can happen. I believe you have drilled down to the pump being defective, or worn out. Of course test equipment will prove the theory, but I surmise the fault has been proven.
Years ago I had a diesel Rabbit that was wrecked and given to me by a coworker. Ran really well but severely underpowered. Had a friend that used to road ralley a Sciracco and blew the engine up the second time so we concocted the thought of marrying these two up. I fitted the engine to the transaxle, and fabricated an intake manifold holding a small Mitsubishi turbocharger to the engine. Another friend at the fuel shop turned the fuel rate up and installed larger tips on the injection nozzles. Once running, this thing was a "terror" to drive on anything but a closed course track. It would easily burn the tires off the rims, (torsen-gleason front differential) and when zipping around the pylons would lift the inside rear tire off the ground almost 16 inches. I made frame stiffening bars to control flex and this made the car was a serious contender besting many Mustangs, Camaros, and other competitors. The only diesel I remember and the engine never did give any serious problems. The car went from being "prey", to a "predator" with the boosted aspiration on the tracks. I was shocked the bottom end held together but it did have a forged crank and fairly "beefy" rods. I discoved this when replacing the oil pan gasket and engine seals as throwing the car around violently revealed oil leaks. While the pan was off an appropriate windage tray was incorporated to keep oil slosh down.
The good old days.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heliarc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2025 at 10:36am
This isn't carrying on like an empty hydro pump, more of a slight buzzing and it does out. I figure that's the cavitation you're talking about. I hear that every time and in a split second afterwards the flame dies. Inside the pump you wouldn't really think anything is wrong but that's probably where feeler gauges come in to play. Not sure where I can even find this pump. It wants to run at 1725 or 1750 RPM and all the ones I've seen are around 3K RPM.
Yea the IDI NA diesel was not built with any kind of performance in mind. They were thrifty, had one that would run at 51MPG, tough little things, and simple, but acceleration was miserable. Top speed of about 80MPH, good enough. I still managed to get speeding tickets with them. I've heard of governor mods that will give you more fuel into the meat of the powerband and turn them into something completely different. It's not like a tractor governor. It'll still rev to destruction, I guess it cuts the fuel down a lot when you hit a certain RPM for fuel economy. Now even the factory turbo diesel setup on an IDI, there you're getting somewhere. Still not a hot rod but going from NA to TD was huge for me. Then I got behind the wheel of a TDI once, Jeepers! Barring an Audi Coupe with the 5 cylinder, that TDI was the fastest thing I drove up a mountain around here that I sort of used as a dyno. The TDI hit 64MPH, the 5 cylinder managed 67MPH. I never got into the wizardry you did though. Was the TD setup in the Scirocco?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2025 at 10:57am
Yes, installed into the Scirocco. Cylinder head temps were a concern but an external water pump, and propylene glycol coolant took care of that concern. Car had good manners when driven aggressive, but not so good at low speed.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heliarc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2025 at 11:47am
You turned that engine on it's head. It wanted a good spanking at that point!
I found a pump on E-bay. Used, about $60. Seller says it works fine but I'm waiting to see if he personally saw it run and I want to know why it was removed. No returns on it so at least I want the guys word that it's good. It's a Webster 1725RPM but it has fittings in different places. The return is blocked off with a plug. I figure I can use it if I make lines. I don't think I can use my originals as they are. Likely came out when someone converted to propane or pellets or something. We'll see if the guy replies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2025 at 12:03pm
They were configured in both single, and two line setups. Depends how far the supply tank was from the pumping unit. Sometimes the end plate, (or bell) can be removed and remounted aligning the ports as needed.
Had several Beetles in the 70's and most were used to build buggies with. Several 68 and prior as the more rigid transaxle. Type II, (Squareback) and type III were the cat's meow to build upon as the strongest available. That Rabbit engine was my first foray in liquid cooled VW engines. Along that timeframe I was dating my wife and we decided to marry and start a family, so priorities changed.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heliarc Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2025 at 12:59pm
Bought a used pump from E-bay. Installed it, pump doesn't suck fuel from the tank. Gravity feeding works fine though. Comparing the two pumps, the adjuster on one is run way further out than the other. Original pump would suck fuel just fine. Both Webster pumps, slight differences between the two but nothing fundamental. At least I know something is going on with the original pump now. The used pump will run as long as you want so long as you gravity feed it.
This page was generated in 0.119 seconds.
