Allis u
Ol case mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ol case mike Quote  Post ReplyReply Direct Link To This Post Topic: Allis u
    Posted: 23 May 2025 at 6:02pm
Is it possible to put unstyled WC rear axle hubs onto a allis u I don’t have 28 inch rims to put on it there rotted out rear spokes off a WC sure would look better to me even if they are only 24 inch wheels
Mfam8 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mfam8 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 6:45am
No. Or not without a lot of work. The rear end is just so different between the two models. The U is attached via a Splined center, and the WC has a bolt on hub. For an early U, they used a round spoke wheel for rubber tired tractors, or a flat spoke setup for the steel wheel tractors.... that being said,  It would take quite an adapter to accomplish it, and to have them made you would have well more in it than finding a set of U cut offs or original steel wheels and having a set of cutoffs made from those.   The later U setup used a cast center hub, with 28" deep drop rims. Those rims are still available. I see U cut offs for sale from time to time, so if I were in your shoes, I would put an ad over on the classifieds and try to find a good set of U rear cut offs. Or find a U parts tractor, which is not too hard to do, although finding one with good rear rims/wheels is a little tougher, but not impossible by any means.  Good Luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ol case mike Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 2:58pm
Yeah I am needing 28 inch wheels with drop centers I have few sets of spoke 24 an junk wc carcass was just a thought
