AC 6070 |
Sab
Topic: AC 6070Posted: 23 May 2025 at 11:18am |
I am a new owner of AC 6070
I have trouble to change my HT oil . The rear is done (near the three point hitch) Oil is drain in front axle , but i dont find the way and location to fill it again . I know that the level is determined by the wheel. Also do I have an another place to drain and fill. Filter is changed. I have the MAnual but dont find the place they explained it (operator and service)
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3546 |
Posted: 23 May 2025 at 1:09pm |
The most important check is the TRANSMISSION . It checks and fills via plug on the side of the housing under the platform on the brake pedal side. Many owners drain both compartments, fill the rear end - and drive for a couple of miles and the whole tranny locks up. IF you are talking the front outboard planetary the check plug is the fill plug. 1/2 way up. The center cavity has a 22mm drain plug on the bottom and another one for the fill. You need to do some more looking in the op man for the service areas.
Mikez
Posted: 23 May 2025 at 2:10pm |
I would get yourself manuals, owner operators, parts, service. You can buy all three from agco publications.com or search around on other online places.
