7000 Water temp sending unit HELP
cmalcom20 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmalcom20 Quote  Post ReplyReply Direct Link To This Post Topic: 7000 Water temp sending unit HELP
    Posted: 22 May 2025 at 3:14pm
Have a 76 7000 with a non original motor. I bought a new temp sending unit because the old one quit. I either bought the wrong one or am looking in the wrong place for the old one. Attached a pic of what I think the old one is. Thanks for the help
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2025 at 3:38pm
Looks like the right place, IF wire is a little short look for other plugs on that Thermostat Housing. Don't put too much sealer or thread tape on the sender as it can interfere with the sending unit being able to ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2025 at 4:09pm
You can just use a pipe bushing to make it fit the hole. The problem is, it may not be the correct ohms to work with the temp gauge in the cab. The correct sender p/n is 70241249 for a maroon 7000 tractor. What do you have ??
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2025 at 6:30pm
Your in the right place. Have you taken the black tape off to look at the condition of the splice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmalcom20 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2025 at 7:16pm
I ordered from stiener and it is the replacement for that part number. I think the guy i bought it from said the motor was out of a combine if that makes a difference. The thread size is to small and the stud size is to big on the new one.
Edited by cmalcom20 - 22 May 2025 at 7:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2025 at 7:21pm
Combine motor makes no diff at this point. If it is the correct p/n, it should be compatible with your gauge in the cab. Go to your local hardware store and get a pipe bushing to make the threads the next size larger diameter. Don't use much or any pipe dope on the threads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmalcom20 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2025 at 7:24pm
Thank you for your help
This page was generated in 0.289 seconds.
