WC Puller
D_sarver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D_sarver Quote  Post ReplyReply Direct Link To This Post Topic: WC Puller
    Posted: 22 May 2025 at 11:55am
Hey, I am new here and am trying to get into pulling, I have a few wc s sitting around with bad engines and have heard of people putting d17 gas engines in them but that made me think of putting a d17 diesel engine in one... Is this possible if so what needs to be done? On another note I would also like this to still be a useful tractor would there be an easy way to add a dual remote setup to a wc tractor?
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2025 at 6:16pm
That's a pretty definitive no to both questions. For the diesel install you would need virtually everything from a WD45 diesel. good luck finding those parts or committing a travesty of parting one out. Also since WCs don't have any hydraulic system to start with, you'd need to address that before doing anything with remotes.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2025 at 8:05pm
A lot of guys that are pulling WC's are using the original block with a 4.5" stroke (stock WD45 crankshaft) from a W226 engine. It's usually a very easy conversion. If you go from a stock 4" bore to aftermarket 4.125 sleeves, you end up at 240 cubic inches.
I remember my uncle's WC had a PTO driven hydraulic pump for the loader. something similar might work for a remote.
The d-17 diesel engines are very expensive to rebuild and can be hard to find parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2025 at 10:08pm
The engine many have been using is a Gleaner model "E" or "E-3", which is essentially a D-17 engine and known as the G-226. They are 63 flywheel HP at 1650 RPM. A WD-45 (W-226) engine (4.5" stroke) if equipped with D-17 pistons and sleeves (7.25 to 1 compression ratio) will also produce 63 flywheel HP when using the right governor spring. 4 1/8" bore pistons that have lower compression (6.5 to 1 ) won't make any more HP.  More compression is key to making more HP. The best hydraulic system pump for a WC tractor is a 400 series loader front pump driven off of the crankshaft. It fits under the radiator out of the way and is high volume at 10 GPM or more.
