WTB D 10 front spindle locking bolt
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: WTB D 10 front spindle locking bolt
    Posted: 21 May 2025 at 3:46pm
I need a front axle spindle locking bolt for a series III d-10.   may not be using correct name, it's made like the locking bolt on the starter , not sure if it's the same size. any help appreciated keith so. va.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2025 at 5:07pm
You looking for 207872 set screw. Believe It’s still available from agco
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2025 at 6:42am
Same as starter lock bolt and many other uses. I have a parts drawer full of them. I'll most likely be a tractor pull at Victoria, Va. on May 31. Is that anywhere close to you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 4:50pm
Yes it's less than an hour. There's a guy sending one from carolina, if that doesn't work out I'll be in touch , Thanks, keith so. va.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2025 at 6:21pm
The pull will start at 6PM. From what I've been told, my class (Turbo Tractor) which isn't listed will be first.
