8550 engine
TrentH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TrentH Quote  Post ReplyReply Direct Link To This Post Topic: 8550 engine
    Posted: 18 May 2025 at 7:34pm
We have a 8550 that the rear turbo started smoking and will not clear out even when it’s at operating temp and has what we think is a miss on one of the rear cylinders. Is it worth fixing the Allis engine or repower with a Cummins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2025 at 8:04pm
If it was as simple as changing out one injector, why wouldn't you fix it ?? Looks like some good diagnosis is needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TrentH Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2025 at 8:15pm
Haven’t dug to deep into it yet. It looked like more of blue smoke, like oil. I was thinking it was probably rings. Was going to check for bubbles in the antifreeze and make sure it wasn’t that to.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2025 at 11:10am
Dad had a 4w305 that started smoking out the front pipe. It was a lifter, cam lobe, blued and bent push rods, and adjusting screws.
On the rocker arm shaft, grind the smallest of grove from the oil holes @ 4:00 up to 2 & 10:00. That will make it easier for oil to come up and out the rockers and down to the adjusting screws, push rods, lifters, and cam. Also which to green dot rubbers on injector lines. Very best of luck!!!
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2025 at 10:48pm
one bad injector will take out a piston pretty quick and somthing wrong with the valve lash will hammer a push rod a part and ruin the cam  so i would be for checking the injectors and valve train soon we are doing a 504 case engine some messed up the overhead so now its a out of frame major
Post Options Post Options   Thanks (0) Thanks(0)   Quote TrentH Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2025 at 4:40pm
update on the engine the #6 injector was bad so we got the injection pump and all 6 injectors rebuilt and it still has a miss fire on #6 the intake valve is super loose and not opening what could have caused this could the lifter or pushrod be bad or just out of adjustment?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2025 at 4:47pm
A worn out camshaft lobe on that valve/rocker arm is first guess. But, adjust the lash and see how it runs. If the cam lobe is wearing out that valve will get loose again. An engine oil sample may also show that's what it is by high iron (FE).
